Archive
Hello Experts,
I get a ‘Failed to launch Help Client’ error message when I launch the help client in Adobe Encore CS6. I tried uninstalling and reinstalling this software a couple of times. But every time, I end up this error message. Why is the Help Client refusing to launch? I find that in my most recently downloaded version of Encore, the Help Manager is also present. What else can I do to fix this issue? Can someone suggest a way to manually copy the missing file alone to the specified location, so that I need not go in for...
Read moreHello Everyone,
I purchased few DeskScapes from Impulse but I find that I am unable to download these on to my computer. Whenever I try to download, I end up with this error that says ‘Server not responding, Please check your internet connection.’ I find that my internet connection is working fine and I’m online and can access files from it too. It is only the download of these DeskScapes that does not seem to work. What could be preventing the download? I am running Kaspersky antivirus on my computer and I tried disabling and downloading. But this step too...
Read moreI never really tried using my DVBViewer after some months of installing it. But now, everytime I am trying to launch my DVBViewer, an error is appearing. Following with the error message is a black screen. This happens after the recent upgrade of my Windows XP Pro to SP2. How can it be resolve?
DVBViewer Error
Impossible de trouver I'interface du filtre Audio/Video B2C2 MPEG2, error: 0x91000101 or Cannot locate B2C2 MPEG2 Filter Audi/Video Ctrl. Interface
(B2C2 Filter Error. This is probably caused by wrong tuner settings and/ or the trial to tune an encrypted channel)
Read moreHello
My adobe Adobe Media Encoder CS6 failed to launch the help client and gives an error message conveying the same. Why did I fail to download the files necessary to launch the help client? Is this an issue with the installer I downloaded? I tried downloading the installer again after temporarily disabling my Firewall settings. But this method too does not help me to resolve this problem. I tried uninstalling and reinstalling the software and it gives me the same result. Did anyone else encounter a similar issue? If so, Can you please share a fix for this issue?...
Read moreHi everyone! I just want to ask if someone here is encountering this annoying message:
Unhandled exception
An unhandled exception occurred. Press "Abort" to terminate the program,
"Retry" to exit the program normally and "Ignore" to try to continue.
Abort Retry Ignore
This happens when playing a specific game, when loading PDF files, or even when I try to open large files. I don't know why it incurs and I also don't know how to fix it. Clicking on the Retry or Abort will just show the same error message. Clicking the Ignore button will close the message...
Read moreHello Experts!
I am having problems on opening a file in MacPaint X through the Open With... Option. I usually get the error "You can't open the application MacPaint X because it is in the Trash. To open this application, move it from the Trash." Opening the file from the App menu works just fine. How can I fix this? Any help will be appreciated. Thanks!
Whenever I starts Adobe LiveCycle Workbench ES, it always shows an error as shown in the image below. It always happen even if I just restarted my computer ensuring that I have no other application running. I want to know why this error appears and if its possible to help me resolve it. Thank you.
Workbench Error
The LiveCycle Workbench workspace is currently in use.
You must close the other instance of Workbench to proceed.
Read more
I am getting this error on my Mac PC simultaneously:
Shockwave Player Error
To view the movie, open your browser in the 32-bit mode.
1) In Safari, select Applications/Safari in the Finder and click More Info.
2) Ensure that Open in 32-bit mode is selected.
3) Re-launch the browser.
I did what is written in the Error message but the error still exist. Also, it usually happens when resetting Safari and closing it. I just want to know how to get rid of this error or just install Shockwave if needed. Thanks.
Read moreHi Friends,
I have been using Pro Tools for some time now and never had a problem with it. But today this hardware is not installed or is used by another program came as a surprise to me. The error message leaves me quite clueless as to what hardware Pro Tools is expecting. It only give an OK button which when clicked closes Pro Tools. I was running only Pro Tools 9 when this error was reported. Does anyone have ideas regarding the hardware that Pro Tools might be missing or any work around for this issue? I am running...
Read moreHi All
I am trying to install ROBOTC for Mindstorms and am greeted with the following message during the install process. This happens every time I try to install ROBOTC.I tried closing all other programs before downloading. And I also tried temporarily disabling the antivirus during the download. But while the download completes without a glitch always, I never seem to be able to complete the installation. What could be wrong with the installer? Can somebody suggest a fix to resolve this problem please? I am eagerly awaiting your solutions. Thanks in advance.
Error 1316. A network...
Read more
