Archive
I am facing an error when I try to install the application ‘TextMate’ on my Mac. It says TextMate is from an unidentified developer and should this be opened. I am using Mountain Lion on my machine. Why am I getting this error? I didn’t open TextMate because I was not sure if it would cause trouble in some way. Are there certain applications blocked by Apple? Will installing them harm the system? Or is there a work around to continue using these applications? Please help me with these issues. Your help will be greatly appreciated. Thank you.
Hello Experts,
I recently downloaded the DxO Optics Pro and was able successfully install it and use it. And I am very happy with the outcome. However, I face a problem when attempting to process a photo twice. I am not allowed to rename the saved file inside DxO Optics Pro. Instead I get an error message that says the previously processed file will be overwritten. Why is it so? I now try to rename the firstly processed file before attempting to process it a second time. This I don’t find a convenient thing to do. Please can anyone suggest...
Read moreHello All,
I ran factory reset in my Samsung Galaxy I9003. Afterwards, when I tried to restore my backed up applications from my laptop, I get a Restore Error. I have attached a screenshot of the error received below. I checked the connections to ensure that the device is connected and can be seen on my laptop. What might be causing this error that says the device is disconnected then? Does anyone have any idea please? Was anything wrong with my restore operation? How can I find out? I am counting on your help to fix this issue. Any help...
Read moreHi Friend,
Here is a problem I face when trying to play Dream. I get an mpeg 2 error yet I have the K-Lite mega codec pack installed on my computer which contains the mpeg 2 codec. The link given in the error window did not help me to find a fix for this issue. I downloaded the InstalledCodec.exe, ran it and it only enabled the microsoft codecs but this would still not solve my problem. Also my DeskScapes is installed properly. Please can help me with a fix for this issue? I have exhausted all my possibilities. Any help...
Read moreHello Pals,
I tried to register on Wondershare Youtube downloader with my Registration code and got this ‘Fail to register’ error. It says usage of registration code has exceeded the limitation. But this bit of information puzzles me because this is actually the first time I’m trying to register this registration code on Wondershare. I checked my registration information to make sure that the registration code I’m using is the correct one. Did anyone else face such an issue? How can I resolve this problem? Please help. I am waiting your responses. Thank you.
Fail to register!
We...
Read moreHello All,
I have been attempting to burn DVDs using Creator 2009 and encountered this error. I tried four times and it only helped me to waste blank DVDs each time. I am using windows vista on my machine. I can successfully burn DVDs on this machine using Nero. I tried using Sony, Imation and Verbatim disks to burn the DVDS. But I did not succeed with any of these. I am trying to create disks at 4x speed. I had no issues when installing this software. What could be wrong with Roxio Creator? Can anyone please give me few...
Read moreHello,
I am new to Visual Trader and I have been attempting to setup user data in Visual Trader 4. I could create a new map and then I edited the symbol list and transferred the symbols. When I click on save, I get the ‘Object reference not set to an instance of an object’ error shown in the screen capture below. After closing and reopening Visual Trader, I get another error ‘No data exist for row columns occurred’. Then the VT4 screen opens up and I get the ‘Object reference not set’ as before. And now, when I click...
Read moreI have a Quickbooks Pro 2010 running on my Windows 7 PC. The problem is, it cannot be connected with Quickbooks automation. I tried my old Quickbooks 2009 but it is also not working. Then I try uploading Teapplix file with Quickbooks web connector but it showed an error:
QBWebConnector - Error
QBWC1039: There was a problem adding the application.
Check QWCLog.txt for details.
Unique OwnerID/FileID pair value required
How can I fix it?
Read moreI am activating my account in AB Tutor. I am sure that I am using a legit serial number and I have a firm Internet connection. However, I am still getting an error. How can I activate my account and fix this?
AB Tutor Control
Sorry, but there seems to be a problem with your license.
Read more
I am installing WSUS on Windows Server 2012. On the window "Add Roles and Features Wizard" under the WSUS Role Services menu, I selected the WID Database and the WSUS Services. It continue with the installation but prompted with an error as shown below:
Feature installation
The request to add or remove features on the specified server failed.
The operation cannot be completed, because the server that you specified requires a restart.
I restarted the server but it doesn't change anything because after restarting the server, I also need to restart the WSUS installation which just ends...
Read more
