Archive
I just bought an XPS 12 from Dell and the store tells me that it can play Blu-Ray disk. I also bought Blu-Ray player from Imation together with Nero Platinum 12. However, when trying to connect it to my computer, an error showed up. It is connected through a USB cord from my computer to the Blu-Ray hardware device. How can I fix the error?
Nero Blu-Ray Player
The connection to your display does not meet the system requirements for Blu-ray. Please check your system for HDCP compatibility or use the analog output. (Error-Code(1:0x13,2:0x80400034))
Read more
I am presently running Windows 8.1 and I receive an error when I tried to install BlueStacks. It says, "Error 25000. BlueStacks currently doesn't recognize your graphics card. It is possible your Graphics Drivers may need to be updated. Please update them and try installing again." This happens when running a split installer.
BlueStacks installation failed.
Error 25000. BlueStacks currently doesn’t recognize your graphics card.
Read more
I have been unsuccessfully trying to register Total Uninstall Pro several times now. I found that my Total uninstall has got unregistered when I had completed installing ESET. I took this to be an error caused by a change in my Firefall settings I tried to register after uninstalling ESET. But I was not allowed to register with a registration failed error message .Then I deleted the program rule manually from firewall and tried to register I got another error message which said ‘The order is not valid’. What is causing this error? Can anyone help me to register...
Read moreDear Friends,
I am attempting to create a backup of all my videos on a USB disk using Symantec System Recovery 2011. But I cannot save the backup settings because of an error generated by the API. It says that the backup settings could not be saved as the system cannot find the path specified when editing offsite settings. I chose to create SSR Disk on USB in the Create Symantec System Recovery Disk panel and selected this USB from a list of available devices. Then why does it give me path cannot be found error when editing? Do you...
Read moreHi Everyone,
I am trying to use a 30 day trial version of WindowBlinds. I downloaded WindowBlinds640_public.exeand installed it. Soon after installation, when I try to load it, I get this ‘Version Expired’ error shown in the below attachment. Clicking OK takes me to a WindowBlinds purchase only window and I not allowed to make use of the 30 day trial period. I uninstalled WinowBlinds rebooted and then tried proceeding with a fresh download from another site. Here again I had no luck. Does anyone know of a 30 day free trial version of WindowBlinds? Thanks for the info.
I want to know why I am receiving error on Mac Mountain Lion OS X 10.8 when I installed Symantec Endpoint Protection. It also appears on some applications that I tried to install on my Mac. The error is stating:
"Symantec Endpoint Protection.mpkg" can't be opened because it is from an unidentified developer.
Your security preferences allow installation of only apps from the Mac App Store and identified developers.
"Symantec Endpoint Protection.mpkg" is on the disk image
"Symantec_Endpoint_Protection12.1.1000.dmg".
How can I change the security settings in Mac so it will allow installing programs? Any ideas? Thanks.
Read moreHello Friends,
I can’t activate the installation of Music Morpher because I keep getting the error shown in the below attachment. I have tried downloading two different versions of the installer from audio4fun.com and both failed to initialize. I also tried downloading in different browsers. But nothing improved my situation. I am using Norton antivirus in my system. Could this be hindering the download in any way? Or am I using a corrupt version of the installer? From where can I download the correct installer? Please advice. Thanks a lot for your help. Regards
Could not initialize...
Read moreI just installed Pinnacle Studio and whenever I started it, the error "The Operating System has been upgraded after Pinnacle Studio has been installed. Some or all of the program's features may not operate correctly. We recommend that you re-install the software." appears. I can't uninstall Pinnacle since I need this for my project, so can someone please help me on fixing this? Thanks.
Hi Experts!
I would like to ask how I can fix the issue I am encountering when installing Skype on my Windows 8.1. I am getting an error message. This same error appears when I install SkypePortable on its sandbox. I am running Windows 8.1 64-bit and Sandboxie 4.07.01. Both are activated and updated. I am used to installing programs on their own sandbox so my computer system won't have any entries left if I decide to delete the program. Please help me.
Skype.exe - Application Error
The instruction at 0x76aab1b0 referenced memory at 0x00000009. The...
Read moreHi All,
I was trying WindowBlinds 8 in my windows 8 laptop. After completing the Installation smoothly, I copied the Keygen(RNDD Repack) into the Installation folder and then ran as administrator. It saved the license successfully but when I tried to Patch I got the error ‘Cannot open file’. I disabled the service and tried patching and still I get the same issue. Did anyone else face this issue? What did you try to resolve the problem? I cannot imagine what more could be done to prevent this error. I am waiting for your responses. Thanking you.
