Archive
Hi All,
I have a problem with CS5.5. When I record from Audition after making a new file, I get an error that says the sample rates of audio input and output devices do no match and that audio cannot be recorded unless this is corrected. I was able to open an existing MP3 file and play it without any issues. This problem is only with trying to open a new File. I am using a windows 7 pc and my Audio hardware setup is as follows: Device Class: MME, Default Input: Microphone, Default Output: Speakers, Master Clock: In: Microphone,...
Read more
I have configured SIP Trunks onto my Lync 2013 Server. When I try to place a call from the client to a PSTN network, I get a call could not be completed error message. I have configured SIP trucks as follows: I downloaded the latest topology from CMS in Topology Builder and saved it on the local hard disk. Then I edited the properties in PSTN Gateway properties of the Mediation Pool to ‘Enable TCP Port’. Next I proceed to define a new IP/PSTN Gateway by entering the IP address of the PSTN Gateway. Then I changed the SIP...
Read more
Hello All,
I have been using FL Studio for 4 months now and did not have any issues so far. But now, I get an access violation error in ntdll.dll module while rendering my Flp project. I am using Windows XP professional and DirectX 9. I tried restarting my computer and reopening this project in FL studio several times. But every time I get this same error. What could be wrong with FL Studio now? I am absolutely in the dark. Please can anyone give me a solution for this error? Thanks a million.
Access violation at...
Read more
When creating an Aggregate Device in my Mac, Audition cannot attach, even though I'm only assigning the built-in microphone to it. From the audio hardware preferences screen, when I try to choose the Aggregate Device, Audition throws out this error:"The device in currently in use by another process". I've tried closing every other program and tried assigning the device, but still the error persists. Can anyone please suggest what else I’m missing out and help me solve this problem? Thanking you for sharing your suggestions.
The device settings could not be applied because the following error
occurred:
The...
Read more
Hello Everyone,
I get this error when trying to install BlackBerry Link. I cannot think of any more methods to resolve this issue and Google had no helpful suggestion to offer. The error tells me that a previous version of the file is preventing the installation of the link. System restore is disabled on this system. I tried to manually remove the BlackBerry Desktop software by deleting registry entries, files, drivers and software. And then I rebooted it. This did not help the situation in any way. Can anyone find a solution to this? Thanks a million for your help.
Read more
Hello All,
When attempting to transfer an SQL database from one server to another server using the Copy Database Wizard, I get an error which says SQL agent is not running on the destination server and that the wizard will not function properly. Here is what I tried: From the SQL Server Management Studio, I choose the option ‘Copy Database’. Now on Select a source server page, I specify the server with the database to move. After entering the login information and authentication method, I establish a connection with the source server. Now from Select a Destination Server page I...
Read more
Hi All,
I have got GraphEdit installed and I am able to play a file with core DTS instead of DTS-MA using AC3 filter, that is the filter I chose to use. However, I get an unsupported error message before the filtergraph is built and the video or audio is played back. Could you tell me how to avoid this error shown in attached screenshot? I would prefer not to install ffdshow because I would like to keep a dedicated filter for every separate directshow component. So if you could you please suggest a work around to fix this issue...
Read more
Hello Pals,
I am trying to load an flp file, but it will not load my kontakt 5 settings and I get the error message shown in the below screenshot. These are the steps I followed while setting up Kontakt5 in FL Studio: I added Kontakt5 as a channel in FL Studio. Then I connect Kontakt5 to FL Studio by editing the wrapper settings and set the input port to 0 in MIDI section. And then chose ‘Automap outputs’ from processing tab. Next, I configure the output stream for every instrument. Finally, I add MIDI outs for each instrument and...
Read more
Hi
I am getting ‘Not a Manga Studio material’ error message when attempting to install Manga Studio 4 materials on windows machine. I am trying to install the Manga Studio Debut version and downloaded the EXE file on to my desktop. Then I ran the EXE file to extract the installer. Finally I try to install using this installer and I end up with this message. I tried downloading the EXE file again and completing the installation. But I failed to do so. What could be wrong? Can someone help me with a solution to this problem? Thank you for...
Read more
