Archive
Hello All,
I recently installed the beta version of SolveighMM Video Splitter 4. The installation was successful. I have not tried adding a AVI file, but I cannot load a WMV file into the SolveigMM Video Splitter. Loading results in a ‘Can’t init keyFrameManager’ error. I thought perhaps it did not install properly and tried uninstalling and reinstalling the same a couple of times. But every time I try to load the file, I am back to square one. What am I missing? Please advice. I am clueless as to how to fix this. Thanking you for your support. Regards
I was having issues with getting my PhotoSmart 309g to work with Snow Leopard. I wanted to uninstall this software and try again, but I am unable to do so because of an error. I cannot proceed with uninstall due to a missing uninstaller plugin. What is causing this error? Can these missing plugins be replaced somehow? Or can you suggest a work around for this issue that would enable me to uninstall the software without these plugins? Please help me out. Thanking everyone for spending their valuable time on this issue. Regards
Plugin Not Found
Uninstaller.plugin...
Read moreHi Experts,
AfterEffects CS5 fails to launch with a warning. I get a ‘Could not rename file’ warning with a file name path. The complete warning message I get from After Effects is shown in the below screenshot. But the strangest part is that such a file does not exist in my system. I attempted checking for this directory on the terminal too. And I failed to locate it. I have run permissions and restarted my system but still this message refuses to go away. What might be the reason for displaying this unrelated warning? Does anyone have any idea?...
Read moreDear All,
I can’t install ArcSDE 8.3 on windows machine because of the error:’ you do not have access to make the required system configuration modifications. Please rerun this installation from an administrator account’. I can’t understand why I am getting this error because I am the only user on this computer and I have administrator privileges. I am using windows Vista on my computer with all the latest updates. Someone suggested creating a new administrator account and tried creating an administrator account with a new name. But this did not work for me. Can anyone help me with a...
Read moreHi,
I am trying to download the FL Studio 8 version I bought, and I keep getting this error when I press "install" about 2 seconds into the install. I tried installing several times, but every time I get this ‘Error opening file for writing’ message. I tried installing after temporarily disabling my antivirus but this step too proved to be futile. I am running the installation with administrator privileges and I’m using windows 7 OS. I have attached a screen capture of the error received below. Can somebody help me to spot the trouble with this installation? Your help...
Read moreHello Friends,
I am facing an issue with the importing of custom indicators in NinjaTrader. I have recently upgraded to V6 of Ninja Trader and I am getting the error message that generating indicator has resulted in a compile error. These indicators were working smoothly on V5. I tried reinstalling the upgrade, but this did not fix the issue. So I tried going back to V5 and now I find that these indicators don’t work with V5 as well. What could have corrupted the indicators? Please can anyone help me to identify the reason for this error? Thanks in advance...
Read moreHello All,
I am using OmniTrader 2013 Pro with MetaStock EOD data. When I attempt editing data in the Focus List right click menu, I get the error ‘Object reference not set to an instance of an object’. And when I click on the OK button, it brings the following ‘No data’ window. This problem occurs when I right click on a symbol in Focus List and then click ‘Edit Data’ instead of opening the editor window. I do not know what is causing this issue. Does anyone have any ideas as to what could be the reason for this...
Read moreHi Everyone,
I installed ReSharper 4.0.770.31 last week. The installation completed smoothly and afterwards I attempted to launch Visual Studio 2008 to see what had changed and I receive with the following fatal error message from ReSharper. I tried repairing the product and when this failed to resolve the error, I uninstalled ReSharper and reinstalled it. But I still get this error. Later I tried installing ReSharper 4.0.769 and here again I face this same error. Does anyone have any ideas as to how to fix this issue? Thanking you for all the suggestions. Regards
JetBrains ReSharper...
Read moreHello,
I installed the latest daily update of CHIRP (chirp-daily-20120720-installer). When I start CHIRP, it boots up fine. I clicked on radio after attaching an Alinco DR-235 and using an Icom OPC-478 (RS-232 to radio cable). When the download from Radio begins, I get a short flash of the 'cloning' popup, and then an error window is shown before the daily update. I tried this with the CBTI Alico mobile software with the same cables and settings and it worked fine. What could have caused the error after the installation? Please advice. Your help will be greatly appreciated.
I am attempting to run StyleGuard application and I get the ‘Initialization Failed’ error message. I was able to complete the installation smoothly on my Mac 10.8.4 machine. But I cannot run this application. I have Microsoft office 2011 installed on my system. Is this error a result of missing to install any other components during installation? I tried running the installer few times and running the StyleGuard. But every time I encounter this error. I have no idea as to what I could have missed. Can anyone shed some light on this issue, please? Thanks in advance.
