Archive
Hi Experts
I want to reinstall Outpost Firewall Pro but I face this error that says a previous version of the same is present in the system and that this must be uninstalled to setup the new version. I had downloaded a new copy of the installer from Agnitum. I also verified that I had been uninstalling the software from a user account with administrative privileges. I am using windows XP Home Service pack 3 and Avast antivirus on my desktop. Can someone guide me to complete the installation properly please? Thanks a lot for your help.
Read more
Hi
I'm getting an error with Media Player Classic Home Cinema and I have no idea regarding what to do to fix it. The complete error message is shown in the attached screen capture. I have installed the latest version of Media Player Classic. I tried to reinstall Klite Codec pack and also tried to update it. But none of this helped to improve the situation. I am using windows Vista OS. It was working fine till last week. And as far as I can remember I have not changed any programs on my computer. What could have gone wrong?...
Read more
Hi All,
I have been trying to install Steganos Security Suite 2007 without much success. The installation fails with an ‘Error opening file for writing’ message. I tried aborting the current installation and tried installing again making sure that I had no other programs open. Again I get the same error. I remove the installer and downloaded a fresh version of the installer. But even after trying to install from this, the problem persists. How can I resolve this issue? Is my installer corrupted? I hope someone can help me with a solution for this issue. Thank you all for...
Read more
I consistently get an AppleScript error when I try to make a DVD or import an mpeg file. It won't open a terminal and errors out -1728. I have tried using different file sizes from a small 1.2 MB file to a large 7 GB file. But no matter what type I try, I always get this error. I have tried using several older versions after deleting the existing 0.9 version completely. But none of the versions seem to work for me. Please help me figure out what is causing this problem. All the installations had gone smoothly for...
Read more
Hello
When I try to simulate intraday data on MS Simulator, I get this error 1617 that says the directory does not contain any MetaStock files. The file still opens in MetaStock but I get this error message both before and after opening a file. This began after my usual download of the day’s data and automatically running the MetaStock export. This happens to all my MetaStock folders. I have not made any changes after the download of the data for the previous day. I have not had a similar problem before. What could be causing the issue? Please help....
Read more
Hi Experts,
I am unable to import any video format in PopVideo Converter. I have tried avi, mpeg and mov formats. Nothing works. All I get is a video codec missing error. I also tried importing a popVideo file into the converter. I had exported this file as a popVideo file from CTAPro with default settings prior to importing it. This file too doesn’t work and displays the same error message. I don’t understand why I am not allowed to import the video. Is this a problem with the installer I used to install the software? Please suggest a fix...
Read more
Hello Experts,
My country (India) is not listed in the Lists folder of Visual Trader. So I created my own group by creating a map first and then completed creating groups and assigning “IN” to it. Then I closed VT and copied the map into the folder "IN" under lists and put my custom profile (.vtp file) there and it worked. I am using eSignal RT Datafeed. However, when I restart VT I am greeted with an error message that says ‘Could not find file’. Where have I gone wrong in creating this custom profile? Hope you can help me...
Read more
Hello Everyone,
Here is my problem. Chirp 0.3.1 will receive configuration data from radio but fails to send back the chirp image to radio to complete the configuration. On Chirp, I select radio and choose upload to radio. The port, vendor and model are set to the same values that work for receiving data from radio viz. /dev/ttyS0, Yaesu, FT-60. Then I click OK to begin transmission. Chirp’s prompt appears showing that it is trying to transmit to radio but this halts soon after an error message’ Failed to communicate with radio’. What could be causing this error? Please help....
Read more
Hello Sir,
I am a registered user of Crazy Talk 5 Pro .For about a month now; I have not been able to import any MP3 in wave or Background Audio of the Script Section of Crazy Talk 5 Pro. I always get the same irritating error shown in the screen capture below. The MP3s I am trying to import are of bit rate 128 kbps and can be played without any problem in the windows media player. When I import these into Crazy Talk, I do not get a visual error but it generates a lot of annoying noise....
Read more
Dear Sir,
I attempted installing Sketchbook Designer 2013 version but encountered a problem saying that the language setting must be changed to English or French. I uninstalled it and tried to install 2012 version of SketchBook Designer but again faced this same problem. Is something wrong with the installer I am trying to install? I am using SP 2 of SketchBook Designer 2013. And I use Mac OS X 10.6 with 2 GB RAM. I have no idea on how to resolve this issue. Can anyone help me to correct this problem? Thanking you for your valuable help.
Read more
