Archive
Hi friends,
I am trying to install StyleGuard on my Windows 7 machine and the installation fails to complete with an error that says there was an error while attempting to download the required file. I am using word 2007 on my pc. I tried downloading the installer a couple of times, but find that the required files failed to download. I am using Norton antivirus free trial on my system. Could this be hindering the download in any way? Did anyone else encounter a similar problem? Please give me a solution for this issue. Thanking you in advance for...
Read more
Hi All,
I recently downloaded the new installer of autodesk SketchBook and it installed without any problems. But when I try to enter my serial number and product key, I get an error message telling me that I do not have the necessary system privileges to do so. I have a Mac OS X 10.7 Lion. I verified that I have downloaded a Lion compatible version of SketchBook. Now what else could be preventing me from entering serial number and product key? Can you please help? Thanks a lot for your valuable help. Regards
You do not...
Read more
Hello Experts,
I encounter the rules error shown in the following screenshot while attempting to load the presets. Can someone help me to identify to which preset (or rule) this error pertains to? The error box does not indicate which application this rule is connected with. I tried recreating the whole rule. Here is what I did: I deleted the whole global rule and then attempted to produce it again. But it did not help. I am wondering if this error has anything to do with the formatting of my preset.lst file. I am awaiting your response to resolve this...
Read more
Dear Friends,
Here is my problem. I was able to download Iclone 4.3 without any issues but while trying to install the same, I get an error telling me that the medium from which I tried to install is corrupted. I checked to see if all my local software (flash, .Net etc) was up to date. After verifying this I tried downloading the installer using chrome and then tried to install Iclone. Again I get the same error as in the first case where I downloaded using FireFox. What is to be done? What else could be wrong with my...
Read more
I have Alias Sketchbook Pro and it was working fine until about two days ago. Today, I tried opening it as always and it didn’t open up instantly as it does usually. The palettes took longer to load and then all of a sudden I get the error message as shown in the screen capture below in a screen full of stripes. I am using Intel iMac G5 with Snow Leopard. I have already scanned for viruses and did not find anything. What else could be causing the issue? Did anyone else face this same issue? Please share your...
Read more
Hello Friends,
Here is my problem. I have trying to install Autodesk Education Suite for Entertainment Creation 2011 without success for a couple of times now. Every time I try, the installation fails with error 1334 a file cannot be found in cabinet file. I have administrative rights on this machine and I have been trying to install the software from this user account. I have also tried disabling my antivirus software temporarily to complete the installation. But this too failed to serve the purpose. Can somebody help me to find a solution for this error please? Thanks a lot...
Read more
I'm getting an error on my machine. It says, "SDTray.exe - System Error. Rtl150.bpl is missing, the program must be reinstalled." I don't know where this error is coming since I have deleted some programs recently because I need to free up some space on my computer. And those programs are the ones that I am having issues with so I have deleted it. Can someone please tell me what to do with it? Am I infected with some virus? Thank you.
Read more
Hello Experts,
When I click on the Edit Data in the Focus List right click menu, I get the error ‘Object reference not set to an instance of an object’. I do not have any problem with running OT2013 Pro with MetaStock EOD data. I can load charts and run ToDoList and can do all kinds of analysis. The problem is when I right click on a symbol in Focus List and then click ‘Edit Data’ instead of opening the editor window. Then I receive this error. Did anyone face a similar issue? What can be done to resolve this...
Read more
I was attempting to install the Autodesk Educational Suite for Entertainment creation 2011 on several Windows 7 pcs .Using the same install files on every computer (located on local hard drive), it works fine for all but one system. On this machine I get the error that a required cabinet file for installation is corrupted. I tried disabling the antivirus software installed temporarily and then installing Autodesk Educational Suite, but still this error persists. Is there a work around to resolve this issue? Or is this a system specific issue? Does anyone have any ideas regarding this issue? Please...
Read more
Hi All,
I came across this peculiar behaviour of R studio when I tried using q or quit inside a function. When R studio has to deal with such a function, it causes a fatal error as shown in the attached screenshot of the error. But the same function in rgui cause R studio to stop as expected. And similarly using just q () in R studio closes R. It beats me how can q in a function alone cause R studio to crash? I am curious to know if anyone can replicate this issue. Please can anyone give me...
Read more
