Archive
I need to import Twain SANE plug in into Photoshop CS5. This plug in is shown only when running Photoshop CS5 in 32 bit mode. To do this, I had to close Photoshop and go into application and select Command-i to open the info box. And then I clicked Open in 32-bit mode check box. After this I ran Photoshop, and chose Import from File menu. Here I find the plug in listed. However, when I choose it, I am greeted with this error message. I don’t know what is wrong with the procedure I followed. Can anyone help...
Read moreHello Everyone,
I have been trying to create a custom known file type on R-studio for an MP4 file created using Sony XDCAM-EX when I encountered the below mentioned error. This is how I tried to create the file type definitions: First of all I found a signature for my known file type. Then I wrote a known file type description XML file. Then I attempted to validate and add the XML file to R-studio. But at this point, I get the below mentioned error and could not proceed further. What should I do to fix this issue and continue...
Read moreHello,
I got this error from Banshee when I tried to launch Banshee after a couple of system resets. I was working with software which caused my system to hang and I had to do a hard reset. Later, when I tried to open Banshee, I got the following fatal error which forced me to quit banshee. I tried restarting it and tried opening Banshee again. But even after trying a couple of times, I’m still getting this fatal error. What might have gone wrong with Banshee? Did anyone else encounter a similar problem? Can anyone help me with a...
Read moreHello
I am facing this frustrating problem ever since I upgraded to Mountain Lion OS. I cannot open any PDF file that I download using Adobe Reader. Whenever I try to open, a message appears, from Adobe’s Reader that says the document is damaged and cannot be opened. The files that were already there on my computer can be opened. This issue is only with the files that I newly downloaded. What could be corrupting the files? I tried uninstalling and reinstalling Adobe Reader with the latest version. But this did not resolve the issue. What can I do fix...
Read moreHi Everyone,
I received the following error when trying to install System Centre Configuration Manager 2012. The SQL Server certificates are not being created and due to this the installation could not be completed. I tried giving full permissions on the cert folder to different accounts like local account, domain admin account, network service account etc. But this did nothing to improve the situation. I attempted running SQL under all those accounts and none of them succeeded in creating the SQL certificate. What else can I try to fix this issue? Please give me some ideas to solve this. Thanking...
Read moreHi friends,
Whenever I launch Avid Media Composer, I get this error message:’ Exception: SYS_ERROR, status: 87, msg: The parameter is incorrect.’ I was using Media Composer 3.5 without any issues. Ever since I upgraded to Media Composer 4, I face this problem. I tried uninstalling and reinstalling a couple of times and this did not work. I thought I’d go back to the earlier version and again uninstalled Media Composer 4 and tried installing the Media Composer 3.5. But now I find that this version of Media Composer throws this exception too. Help!!! What could have gone wrong? I...
I am using DVDFab Trial version and I encountered the following problem while trying to convert a blu-ray movie disc. I loaded the blu-ray disk and made the necessary profile changes. Once the profile settings were completed, I clicked the ‘Start’ button to convert my blu-ray movie. And then, I get an error message which says file already exists. I did try a similar conversion before. But why should it prevent my keeping the earlier version as well as the latest version of the movie? Is there a work around to fix this issue? I am waiting for...
Read moreHi All,
I was creating a new host profile after upgrading a vSphere host from ESXi 5.0 to ESXi 5.1u1but it failed with the error: ’ A general system error occurred:
Error stack: Firewall rule activeDirectoryAll must be enabled for the service Iwiod’
The error message says that the Firewall rule activeDirectoryAll is disabled and the service Iwoid requires that it should be enabled. But this puzzles me because I had used this same host as the reference host for my 5.0 host profile without any problems. How can firewall rules be different for creating host profiles on 5.0 and 5.1? Any...
I hope someone can figure out what is wrong with my ConvertX, this problem frustrates me. If I try to remove a chapter settings pin using the delete key, the screen gets filled with a ‘List index out of bounds’ error along with the chapter number(given in brackets) I am trying to remove. And the only way to get out of this is to kill the process using task manager. I am using ConvertexToDVD4 and I have tried uninstalling and reinstalling the software. But the problem persists. Can anyone give me any ideas on how to fix this...
Read moreHi Friends,
I am getting an Application Error on Convertex while trying to convert a file. I got the following access violation error after I did this: While converting an mkv file, after completion of 30% of the conversion, I pressed Stop. And then I pressed yes to clean up. After that I tried closing the ConvertX and I get the following error. Does anyone have any ideas as to what is causing the problem? Is this a problem with the ConverteX version I installed? Should I reinstall it? Please advice. Thanks in advance.
Exception EAccesViolation in...
Read more
