Archive
Hello All,
I am not able to create a custom System Recovery Disk (SRD) on my computer that has both Symantec System Recovery (SSR) and PGP Desktop Encryption installed. The creation of custom recovery disk fails with an error message. I am using Symantec System Recovery Trial version 2013 on my windows 7 machine. Does PGP Desktop Encryption prevent the recovery disk creation? I had created a recovery disk earlier for a windows XP machine using Symantec System Recovery Trial version 2013 without any issues. There was no PGP Desktop Encryption installed in that case. Do you have any ideas?...
Read moreHi All,
I get an error on startup of my newly installed version of iSpy, the iSpy 3.5.0.0 as shown in the below screenshot. I had no problems while using iSpy 3.4.3.0. But after the upgrade, something must have gone wrong. I thought perhaps the downloaded file was corrupted and tried uninstalling the software and installing it back again. But even after trying to do this many times, the problem still persists. Now I don’t know what changes in my system is causing the problem. I have not installed any new programs apart from this one. Please, can anyone tell...
Read moreHello All,
I installed both the Blu-ray and DVD converter V3.0.0.4b. The Blu-ray works fine but the DVD Converter gives this access violation error message when trying to launch and fails to launch. I was able to launch DVD Converter V3.0.0.3b without any problem. It is only when I tried the V3.0.0.4b version that I ended up with this error. I tried running the installer again but without any success. Is this installer corrupted? How can I get DVD Converter V3.0.0.4b to work? At present I do not have the installer for the V3.0.0.3b with me. Please help me to...
Read moreHello,
I was attempting to create a backup from a blu-ray disk with the following settings: Disk was to be read from Blu-ray drive and shortest version and English audio track were selected. The video settings were DVD 16/9 best quality with video options to default and outputs to DVD9. It crashed at the point that it was preparing the dvd menus, prior to burning. I tried it again with a new version of Blu-ray to DVD and I still get the same result: application completes the conversion and crashes. What could be causing this error? I am looking forward...
Read moreHello All,
I was not able to install Trend Micro Titanium Internet Security2011. The installation stops with an error message that says your computer does not meet all of the installation requirements. I am using windows XP with Internet Explorer 8 on my laptop. I have more than 1 GB of free disk space on my system. Still I am not able to complete the installation though I tried installing 3 or 4 times. What could be causing this issue? Did anyone else face a similar problem? I am looking forward to your help for resolving this problem. Your timely...
Read moreI'm trying to run WD Black2 Installation Software on my PC but it is giving an error message. I can't continue with the process as the error always appear when trying to run it. What is causing this error and how can I fix it?
WD Black 2 Dual Drive
Installation Incomplete
An error has occurred while installing WD Black 2 Dual Drive
Unsupported Windows version.
Completion code: 52
Read moreToday, I am trying to uninstall Mindjet MindManager 2012 through the Control Panel on my PC. However, I am encountering:
Error 1905: Module C:Program FilesMindjetMindManager 10msscript.ocx failed to unregister. HRESULT -2147220472. Contact your support personnel.
I tried to search on the web for possible solutions but it is directing me to a page where I need to perform force uninstall. Is it safe to do this? If no, what are the other possible solutions that I can perform? Thanks.
Read moreHi,
I recently encountered this frustrating error. Whenever I try to launch the game Terraria, I get the CLR Error shown below. I tried reinstalling the game, but it did not improve the situation. Someone suggested that this is a problem with my .NET framework and I tried uninstalling and reinstalling the .NET Framework. But this idea too did not work out for me. I even tried using a .NET cleanup utility and then reinstalled my .NET Framework. All this was useless. I have exhausted all my possibilities. Can anyone help me with this please? Your help will be greatly...
Read moreHello,
I have a problem with my SplitCam. I get an error when I try to open SplitCam which says there is an error with the installation of driver and that I must restart the computer and try again. Restarting it didn’t help. I have tried uninstalling and installing SplitCam a couple of times on my laptop. The installation goes smoothly every time. But when I try to open, I always get this error. What could be causing the trouble? I use windows vista on my laptop. Can anyone help me with this problem? Your help will be greatly appreciated....
Read moreHi
Every time I try to view or edit on my Prezi, I get nearly 10 of these pop-up messages that says ‘Prezi could not load one of your graphics’. Please see the attached screenshot for the technical details of the error. What causes this error? I checked to see if any of my graphics were large. But I could not find any. Are there any particular image formats that should not be used with Prezi? Please can anyone help me to fix this issue? I have an urgent presentation to give and you timely help will be of immense...
Read more
