Archive
I have a system running Windows 8 and I am trying to install the Top Notch/Summit on it but it didn't work. An error will appear if when I continue. It says:
Director Player Error
This projector file is corrupt! Unable to continue.
I want to know if this can run on my Windows 8 and if its compatible. If so, what do I need to make it work? Any help will be appreciated.
Read moreMy Google Chrome is crashing nowadays. And the default homepage which supposed to be www.google.com have changed into something new. Additionally, there are added tools below my address bar and some software is also added on my computer. Aside from that, when I run Malwarebytes to check and clean my computer, it throws an error stating:
Run-time error '-2147024769 (8007007f)': Automation error. The specified procedure could not be found.
What is the meaning of this error and how can it be fix? Please help.
Read moreI am trying to set up CRM IFD then I tried to reconfigure ADFS 2.0 Federation Server but the error appears during the process. I don't know what this means. Can someone please help me?
AD FS Federation Server Configuration Wizard
Existing Web site detected. Therefore, the Web site was not reinstalled.
If you are trying to redeploy the default AD FS Web sites, see https://docs.microsoft.com/en-us/windows-server/identity/ad-fs/deployment/windows-server-2012-ad-fs-deployment-guide for details.
Read moreI just installed the NI Security Update 67L8J3QW. When I try to launch a process under the NI Lookout Server, I received an error message. What can I do to get rid of this error?
Server URL not allowed
Lookout cannot download process files from the specified server URL.
Please make sure the server URL is in the Allowed Web Servers list.
Refer to KB 67L8J3QW on ni.com for more information.
Read moreI am trying to open Transmission from which I've downloaded outside the Apple App Store. However, it keeps showing the error and I can't open it. I want to know if there's a way to open such applications even if its not downloaded from the App Store. If there is a possible way please let me know. The error I got is shown below:
"Transmission" can't be opened because it was not downloaded from the Mac App Store.
Your security preferences allow installation of only apps from the Mac App Store.
Read more
An error occurred when I am working with Astute Graphics on MAC OS. This error message is not so descriptive, it’s an unknown error. It appears whenever I click virtually in the art board. I tried the usual method by reinstall adobe Illustrator and then reinstalling VectorScribe, but no luck in my side. Help to rectify this error and continue my work.
Image of the Error
Error Message in the Image
Error
The filter cannot complete because of an unknown error.
Error: 0SEG
Read moreHello all,
I need webcam badly in my work environment, now it’s not functioning properly. I got an error message, I did all uninstall and installation. I checked the permission with the network, is great. Going to try again by clearing all old data and try to setup everything. Will post you friends, same time need some guidance. Thanks.
Error Image:
Words in the Error Image"
Error
Error 1920.Service Process Monitor (LVPrcS64) failed to start. Verify that you have sufficient privileges to start system services.
Read moreHi Genius,
I am new to Linux world, learning it. To my knowledge I have one authentication agent in my system, but the error message says it already exists. How can I find out there is more than one authentication agent? Is it a bug? If it is how it will be fixed? Help me to fix the issue. Your help is appreciated.
Error Image
Error
GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: An authentication agent already exists for the given subject
Read moreI got an error when trying to run the National Instruments installer on my Mac OS X. Every time I run the installer, the error will instantly showed up. And it is telling me that the nivisai.mpkg is from unidentified developer. This issue doesn't appear when I first run this prior to upgrading to Mac OS X 10.8. How can I fix this?
"nivisai.mpkg" can't be opened because it is from an unidentified developer.
Your security preferences allow installation of only apps from the Mac App Store and identified developers.
"nivisai.mpkg" is on the disk image...
Read moreI am running Windows 7 32-bit and I am attempting to install the embeddedCAD 2012 but the error below keeps showing. It says:
*** ERROR ***
Cannot continue,MicroSurvey embeddedCAD engine core not found.
Press Cancel on the next dialog, and try again after it has been installed.
Contact MicroSurvey Technical Support if this error continues.
http://helpdesk.microsurvey.com/
I don't understand why the error occurs so can someone please help me fix it? Thanks in advance.
Read more
