Archive
Hi Pro,
Need Professional guidance to solve my error, so I landed up here. I got this error when I am trying to save reference in an function global variable shift register. Googled the error message and I got cause for this error is VI reference is invalid. Explain me how to make it valid and solve the issue. Your help is appreciated.
Image of the Error
Error Message in the Image
Error 1026 occurred at Close Reference in cscope run vi.vi->Cscope control driver.vi->Minimum scope.vi
Possible reason(s):
LabVIEW: IV Reference is invalid
Read more
I just upgraded my Windows to 8.1 but did not upgrade BIOS yet. My screen is dim and I am thinking this is because of the 8.1 update or maybe an issue with the Sony and Intel software. I am also receiving the error below when trying to install the Series 8 chipset driver.
Intel Rapid Storage Technology
Failure
The setup program ended prematurely because of the following error:
This platform is not supported.
It doesn't work even if I go to Intel website and download from them directly. How can I fix it?
Read more
Friends I am totally foiled with this simple error. The calendar application is not sync with any other app in the system. On/ off the sync is working, need to find the reason for this and fix it. With IPad it’s working well and good but the problem is with iCloud. Hopefully wait for someone to help me.
Error Image:
Words in the Error Image:
The server responded with an error.
There was an unexpected error with the request (domain NSCocoaErrorDomain / error 1550).
Read more
Hello ally,
I don’t have in depth knowledge in this area; this is completely new to me. Each year I buy this to file my tax, nothing more than that. So I badly need your help allies. I signed online to update my turbo tax, paid online. The update went to some extent and it throws an error. Then I tried to uninstall and install again, no luck. I don’t understand the core problem? Please explain.
Image of the Error
TurboTax
An error occurred while we were checking for TurboTax updates. We could not configure...
Read more
Hello folks,
Finally got Tournament 3 game CD, when I attempt to install got an error message and ended up there. It says some cab files are missing, where do I get those files? I need those to finish my installation successful. And also suspecting CD drive whether it reads well? Good configuration with dual core processor. Guide me please.
Image of the Error:
Error Message in the Image:
Unreal Tournament 3 Error
Error 1335. The cabinet file ‘Data3.cab’ required for this installation is corrupt and cannot be used. This could indicate a network error, an error reading from the...
Read more
Hi DBA,
I am a trainee developer, facing lot of errors in the beginning of my career. Ok coming to the problem, today again I faced one new error. Error message explains me to some extent, missing left parenthesis. This should be in the syntax command line. Is comment also needed to be checked? Help please.
Error Image
Error encountered
An error was encountered performing the requested operation:
ORA-00906: missing left parenthesis
00906.000- “missing left parenthesis”
*Cause:
*Action:
Vendor code 906Error at Line:1 Column:113
Read more
I was unable to open Adobe Photoshop CS4 on my Mac PC. It is always showing an error 150:30. I wasn't able to open Flash as well. The error message is attached here. What should I do with this? It appears to be a licensing issue. Any help guys? Thanks.
Licensing for this product has stopped working.
This product has encountered a problem which requires that you restart your computer before it can be launched.
If you continue to see this message after restarting your computer, please contact either your IT administrator or Adobe technical support for...
Read more
Hi trouble shooters,
Having problem with media player or with system configuration? Not sure because I am not able to play my videos. I made some changes in system’s hardware like webcam, upgraded my hard disk and some increased speed. And also I upgraded my media player to new version. Because of these changes am I getting this error? How to solve this error? In any way license is corrupted? Help please.
Error Image
Media Playback Error
Unable to playback protected content (DRM). Please close your browser and try again.
ErrorCode: 8151
Read more
Hi there,
I am gamer like you, so I got a game Tournament 3 from my friend. Started installation within a while I ended up with an error message ‘error 1305…” gave me two options retry or cancel the installation. When I retry, giving me the same error. I have sufficient space in my hard disk, recently increased my processor speed. Please help me to play this game.
Image of the Error
Error 1305.Error reading from file C:Program FilesUnreal Tournament 3UTGameCookedPCPrivateMapsWAR-Serenity_Necris.ut3. Verify that the file exists and that you can access it.
Read more
Hello Experts,
Working in an educational institution, my job is in the computer lab. Students often bring some Disc to copy their project works, doing this for long time. Compact Disc is burnt regularly in the lab, but when I tried with DVD problem popped.
The disc is empty, clean and I formatted the disc, still not able to burn. I tried it in different system and different operating system too. Nothing is working out. Experts I am waiting for help.
Error Image
CDBurnerXP
Burning error occured
An error occured while burning the disc. Most likely the...
Read more
