Archive
I tried to install microsoft security .NET framework 2.0 SP2 updates for Windows xp but they fail. The same thing happens with updating 4 drivers also. I faced this problem after running Slim Cleaner. The error messages I get are “Security Update for Microsoft >NET Framework 2.0 SP2 on Windows Serve 2003 and Windows XP x86 (KB2789643)”; “Security Update for Microsoft >NET Framework 2.0 SP2 on Windows Serve 2003 and Windows XP x86 (KB2604092)”; “Security Update for Microsoft >NET Framework 2.0 SP2 on Windows Serve 2003 and Windows XP x86 (KB2742596)”.
Read moreIn the context of Wed browser development, what is responsive design? What is fixed layout? What is Fluid Layout? Explain the advantages and disadvantages of each layout? What are the other kinds of layouts used in web design? When do you use a fixed layout with the Pixel as a unit of measurement?
Read moreWhat is Cascading Style sheet (CSS) language and what is it used for? What are selectors? What is a CSS Box model? How does CSS help to simplify HTML ?What is specificity? Explain inheritance in the context of CSS? Name some properties which can be inherited in CSS. Name some other properties which cannot be inherited.
Read moreHow can I protect my Workbook from being copied by others? Can I prevent others from copying the contents of a cell from my Workbook? Where can I set a password to my workbook? Can I set a password so that people can have only read access and be able to modify it? How do I do this?
Read more
I would like somebody to tell me how I can set up my phone in such as way that it can send WhatsApp text messages to my contact email addresses. What I am trying to find out is how can I send WhatsApp message to someone with a yahoo or hotmail email account automatically?
I am concern that electronic devices such as touch-screens can have a negative effect on our eyes. I would like someone to help me find ways and means of proving this assertion. Do you know if the quality of the images or videos on a touch-screen smartphone can have a detrimental effect on our eyes? What screen resolution is best for clear and better images which will not affect the human eye? Which smartphones do not appear to have good screen resolution?
Read more
I need to install a virtual machine on my Windows OS. I am aware there are different types of virtual machines
to download and install on Linux or Windows OS. Which type of virtual machine is most suitable to install on
Windows operating system? Does the type of Windows operating system I am using affect the performance of
the virtual machine?
Hello, I am a user of Microsoft word 2014. Recently I was working on a equation based exam paper worksheet. I usually work with our local typing/ keyboard software and it was working fine with Microsoft word 2010. But as I upgraded to 2014 it is very tough for me to create perfect equation worksheet as the symbols aren't showing. Any person here who have solution?
Read moreRecently, I installed MYSQL server on my machine which runs on Windows operating system. I started having problems with MYSQL so I decided to uninstall all programs relating to MYSQL. So far, I have been able to uninstall everything except one stubborn program called MYSQL Connector Net 6.8.3. For some unknown reason this particular program has refused to uninstall when I use the normal procedure for uninstalling programs in Windows OS. What is the most likely cause of this issue? What alternative way can I use to uninstall this program?
Read more
I would like to be able to view the history of every command I type into the DOS command prompt on my Windows machine. The problem is I do not have a clue how to do this. I am not sure if the command prompt actually saves all of the commands I type. How do I find out if the commands are being saved on a file somewhere? How can I activate the prompt to save any command I type?
