Archive
I have a lengthy video that I need to compress. I have not done this compression before so I do not know how to begin. Please guide me through the process from start to finish by detailing the ideal type of software to use for high quality output. When you compress a video, does that mean the new data file will remain the same forever or you can reverse the process to its original state?
Read moreWhat are the benefits of using optin ninja plug-in software? Have you used it before and how did it help you to accomplish your objectives. Does optin only work with WordPress or it can function on similar web development platforms? How do you deactivate optin plug-in? What other alternative systems can I use instead of optin plug-in?
Read moreCould someone provide me with easy-to-follow step by step guidelines to design a professionally-looking document in Adobe in-design? I am not looking for detailed explanation but simple steps that can get me results in no time. But I would also like a link to a site that gives much more information about using some advanced features of In-design. Thank you.
Read moreI have come across the ‘Agile’ terminology a couple of time but I am not sure what it is all about. I would like someone who has used the Agile software development paradigm to tell me if it is really useful or not. For how long have you used this system? How did you find it? Can you say you can do without it? What other alternatives exist?
Read moreI am looking for someone to give me the right direction I need to take to learn embedded software. Which tools and resources would you recommend I procure to get started with embedded software development? What do I need to take notice of when I embark on this journey? How can I climb up higher and get to an advance level?
Read moreHello, I would like someone to help me find some tutorials on Python programming. I am not looking for any ordinary tutorial but a specific tutorial that you have used to enhanced your productivity whenever you program in Python. Please where can I find such tutorial if it exist and how long did it take you to complete the tutorial?
Read more
I want to set up a small network of computer for a small office space. I want to use a router to connect wireless devices in the office together but I do not know where to start. What kind of router do I need to buy? How do I configure a router for wireless internet network within a small office space?
I have been told that having my Windows desktop full of applications can affect the performance of my computer. I would like an expert to confirm whether having a cluttered desktop does indeed have an effect on how my machine performs? How exactly does a crowded desktop affect the smooth running of my computer?
These Dell Rugged laptops which are out are suppose to provide great survival abilities in extreme environments. I think they look tough and strong but the question is has anyone actually bought any of these two and put them to the test? In your expert view what is the main difference between these two laptops to warrant a high price difference? Which one will you go for and why?
I am looking for a bargain laptop to buy and I am not sure where to start looking for the best deal there is. Could anyone help me make the right choice by choosing the right place to buy a quality laptop that is as good as new? I would like you to kindly furnish me with the necessary website address. Christmas is fast approaching.
Read more
