Archive
Hi all, I am an age old user of Cannon products. Recently I've bought a Cannon LiDE 210 photo scanner. I was working with Adobe Photoshop 7.0. A few days ago for urgency and need I installed Adobe Photoshop CC version. After the Installation, my Cannon LiDE 210 photo scanner isn't working/supporting like before. Is there someone have any idea, why is that happening?
Read more
Hello everyone , I am using Western Digital metal edition portable hard drive (1 TB). As it was only just a storage, it worked fine. But when I'm loading windows 7, it just can't keep the windows files. Every time I want to boot from portable device it says- wrong media or corrupted file. Can anyone tell me why is this happening?
Read more
I am unable to hear my caller on Skype. What are the things that I need to check for? What is the Skype Test Call? Is it the same as the Echo Sound test service? I don’t see this listed in my Skype. How can I access it? I am using Windows XP. How can I configure it to make Skype work?
Read more
How can you number pages in word? What are the two options to insert page numbers into a word document? How can you delete numbers in MS word? Is it possible to remove page numbers only from the first page? Where in the tool bar can you find this option?
Read more
What is Minification? What is it also known as? What is minified source code and what is it used for? How is It different from data compression? Why is the concept of Minification very important in the context of improving web site performance and reducing web page loading time? What is Ziproxy? How does it work better when compared to other libraries?
Read more
What is an Application programming Interface? Name some important APIs in the context of software applications. What are some qualities of a well designed API? What are some defects of a poorly designed API? What are the considerations to be kept in mind while building a secure API? Why does a company release its proprietary API to the public?
Read more
What is Model View Controller (MVC) ? Why is it useful? What are the components of a MVC? Explain how the components of the MVC communicate with each other.Discuss the use of MVC in designing web applications. When would it be a wrong decision to consider MVC as the design pattern choice?
Read more
Initially my LTE dropped out completely and there was no service. Then I found 1x and now only 3G is available. Slowly the scenario is becoming worsened. I find no connectivity for a while again and no service again. I am really frustrated without the service. Is anybody else experiencing the same? Any solutions please update.
Read more
The wishlist is down in Amazon and not even able to check out properly. Every time I try to check out I get a error with a message “Oops! We're very sorry, but we're having trouble doing what you just asked us to do. Please give us another chance--click the Back button on your browser and try your request again. Or start from the beginning on our homepage.” Does anybody else have the same issue with Amazon?
Read more
Hi, Recently I bought windows 8.1 full version 64 bit. After installing, it was playing soft. But after a few hours of non-stop working the windows is slowing down and the most disturbing thing is happening that, the start menu isn't showing at all (sometimes). Sometimes restarting windows is helpful but not always. Can anyone solve it?
Read more
