Archive
What is information protection? Name some methods used to implement the same in an organization. What should an information protection policy define? What does Information Assurance deal with? Name the techniques used in the Information Assurance method? What forms of data protection is implied this method? What is information Risk Management?
Read moreWhat is an Internet protocol (IP) address? With regard to an IP address explain what is meant by A, B and C class? What is the difference between a Static IP and a dynamic IP? Where are each of these used? Which of these would you term as better in terms of security?
Read moreThe Huffington Post online have posted that Netflix is mostly up, but I wonder why very frequently it is down. Even though the streaming is okay on my iPhone, I am not able to connect through Roku or wii. I repeatedly get errors on loading the videos for a while and quits completely. I am not even able to view the home screen to try fixing it. I really wonder why I am paying for such a bad service from Netflix. Is anybody else facing the same issues with Netflix?
Read moreYesterday I installed GTA V on my playstation 4 and tried playing story mode for few minutes. Then I tried GTA online mode. Immediately it asked me to download an update from PSN and I tried downloading the same. But a pop up says it cannot download the GTA V update. Every time try it, the download stops in very few seconds. Even if I restart the PS4 and try downloading it again but nothing working. Can anyone provide me a solution for this please.
Read moreI was very happy with the introduction of Share Play to PS4 with their recent update 2.00 update. I was expecting to share games with my friends through internet. But I think some bugs are preventing Share Play and creating other network issues. Every time I try Share Play I get errors displayed. Is there anyone else experiencing the same, kindly help me with a solution.
Read more
I want to learn C# in less than one week, what should I do? Please provide me with key guidelines or summaries that will help me get started. I would like to be able to apply the skills to create an application that has some financial benefit attached to it. Why crack my brain for less than a week and not get any reward? Please help me.
Whenever I log in to use the internet on my Windows operating system, I usually go to the network setting to check the speed of the network. Sometimes, I am presented with the option to choose between IPv4 and IPv6 but I don’t have any idea what these two options mean? Do you get a performance enhancement by choosing one over the other? What specifically does each of these likely protocols do?
Read more
I need to learn AutoCad within a week to carry out an engineering design assignment. I need someone to show me the resources I will need to achieve this feat. I am talking about learning the fundamentals and to be able to design components and label them nicely and also know all the other standard engineering practices of drawing with AutoCad. Please your input will be very much appreciated. Thank you.
I want to beef up security on my server network. I need to install an intrusion detection system which will prevent hackers from taking over the network or compromising it. Could you advise me on the best system I can deploy in a Windows environment to ensure that anyone who attempts to intrude or by-pass security protocols will be prevented from doing so?
Read more
What are routers and which one is most effective? I recently bought a router but things did not go according to plan when it came to installing and using it? What I want to know is this, when buying a router for use within a small office space which uses Windows Enterprise Server, what do you need to consider before taking the plunge?
