Archive
Have you found Dell laptops to be very tough compare to other types of laptop you have used in the past? How much heat can they take without the components melting? What is the mechanical limit for Dell laptops? Has your Dell laptop been able to withstand a terrible fall? If yes, how come they are so strong? What kind of materials do Dell manufacturers use to make their machines so strong?
Read moreI need to automate my outlook email program to send automated replies to contacts during out-of-office hours. How can I do this? Could you give me a breakdown of all the steps I need to take to achieve this? Also, how can I configure my mailbox to receive emails with certain keywords only?
Read moreI have a book written in Microsoft Word which I need to convert into an appropriate format for publication as an eBook. Do you have experience converting a Microsoft Word document into a suitable format for eBook? How did you go about doing this? Could you kindly provide simple guidelines that will assist me accomplish this mission? Thank you.
Read moreHow do you encrypt a small network to ensure that people do not intrude and access important and confidential materials? Are there good off-the shelf packages that I can buy to carry out this encryption process? Can I design the system myself or I would need the services of an expert to do this? How can I check from time-to-time that this system is functioning normally?
Read moreWhen it come to setting up a computer network in the office, what options should I pursue? What factors should I take into account before proceeding with this plan? Which particular systems are very efficient for small office network architecture? Which key components must I include in the set up for maximum efficiency?
Read more
How do you layout a book meant for Amazon Kindle in Microsoft word? What margin size to you use for the text to appear well in Kindle? What should be the spacing between the sentences? Is it a good idea to make the heading bold or italic? Which font type and size are most suitable or good-on-the-eye?
Software for Converting Files from One format to another There comes a point in time when a computer user has to convert one file from one format to another. I would like to know, if there is...
I had a Dell latitude laptop which was suppose to be ideal for playing games. After using it for some few months, it started experiencing some problems. The screen went dim and eventually blank. I also had problems with the power button. When I pressed the button the machine does not respond. It only powers on after several attempts have been made. I would like to know why the power button does not function properly had how it can be rectified. Please provide some solution for the blank screen problem too. Have you encountered any serious hardware issues with...
Read moreI have seen some eBooks which have interactivity included in the books. I am new to developing eBooks and I am not sure how to go about adding links to the content so that readers could just click on it and it leads them straight to the page they are interested in? How do I add this feature to my eBook? Thank you.
Read moreIt has been said that it is better not to include page numbers in an eBook. This is because, there are different platforms, for reading the book, and the page will respond in different ways to the different platforms rendering the page number out-of-order. So my question is how do you include page numbers and at the same time ensure that regardless of the platform being used, it will be perfect to read the book, by having everything in order as a normal book?
Read more
Have you ever had any hard disk problem, CD-ROM player problem, wireless problem, booting-up issue, unfriendly keyboard or any other issues with Toshiba laptop. How would you rate Toshiba laptop in comparison to some other laptop that you have used previously? Should I go for Toshiba and why do you think it will be a perfect choice to buy?
