Archive
How do you create a table in an eBook for publication on Kindle platform? Do you have a clue how this could be achieve? What specific steps need I take to accomplish my goal? What about images in an eBook? How do you go about this too? Please enumerate some simple steps to follow to put an image in an eBook. Thank you.
Read moreAre you a regular user of Apple’s Mac laptop? I want to know if there are any peculiar problems that you have experienced since you started using Mac laptops. Has Mac been good to you? Do you find Mac to be highly efficient and has it provided you with a problem-free user experience? Do you find it easy to navigate through the various functionalities without getting exasperated?
Read more
I have seen a handful of software recommended for writing a book for various audiences. Please give me an overview of what epub software is all about and how you can put this tool to good use to accomplish the difficult task of writing a book. Did you find epub very useful or it was a stiff learning slope for you? Would you recommend this software to someone or it is better to get an alternative?
Please, I need help fast. I need to design an eBook for Amazon Kindle. Where do I begin? What do I have to do to get started? What tools do I need and what guidelines should I follow? Could you give me a useful link you have discovered which you feel can be an excellent source of inspiration for me?
Read moreI want someone to tell me which powerful features of Adobe In-design can make a world of difference to the user. I would like to know specific tools you have used to create a document in Adobe In-design. How do you automate Adobe In-design to take care of repetitive tasks thereby saving time? How do you design templates in In-design?
Read moreWould you recommend I buy an ACER laptop? I have not used one before so I would be very grateful if you could give me some insight about ACER laptop. In general, how do you find ACER laptops since you started using one? Were you impressed with this machine? What features of ACER appeal to you?
Read more
Posters are everyday advertising phenomenon. Some poster are quite effective at achieving their intended objectives whiles some fall woefully flat on the face due to unattractive or ineffective design. What steps do you recommend I take to ensure that my posters are of high quality and exceedingly effective in conveying my message to the intended audience and get more-than-expected results?
Which features of Photoshop can I use to create outstanding images or logos? Are there standard guidelines that I need to follow in order to create high quality images? What kind of design features would make an image appear high quality? Which features should I avoid using so that the quality is maintained?
Read moreI need quality images on my website. Could you please suggest which file format the image should be saved in for the best quality picture experience for our site visitors? Which format works best for all kinds of web browsers? Would you recommend I use jpeg or png or something different altogether?
Read more
What is the easiest way to design a webpage in 1hour? The webpage must be secure and also hosted by a web-hosting company. How can I get this done? What tools can accomplish this objective? I heard it can be done in Joomla but I have no experience of using Joomla. How long does it take to learn the basics of Joomla? How do I include security features on the website once I finish writing the codes?
