Archive
I am facing some issues while implementing airspace solutions in WPF. Child and parent windows are not getting clipped and rendered. I have tried learning on clipping behavior of Windows 32 and found that the child windows are totally handled by another thread, which is causing this problem and one can solve this by enforcing WS_CLIPSIBLINGS, but I am not able to implement the same. How can I use WPF to solve this issue efficiently?
Read moreWhat is Reverse Painter’s algorithm? What problem or issue does this algorithm caters to? With just the name it is difficult to identify the area it is applied to but I have heard that it is related to Graphics? Can someone tell me how is it related to computer Graphics? Also I have heard about some flaws in this algorithm, and someone suggested about z-buffer solution, but I have no idea how both of these are related. Can someone please explain me this?
Read moreI'm trying to update my device software through PC Companion. But I keep getting the error: Unable to run update components on your computer. I understand that to be able to run the update, I should have an Internet connection. I checked on all the plugs, router and the likes, but they are all working correctly. What seems to be the issue now? Can anyone help? By the way, I'm using a Sony Xperia X10 device.
Read moreRecently, I've updated my iTunes together with the iPhone Configuration Utility to the most recent versions. But I received an error after doing it. The error is stating, The ordinal 2760 could not be located in the dynamic link library LIBEAY32.dll. After clicking OK on the error message, another error pops up as shown below:
iPhone Configuration Utility failed to locate Apple Mobile Device Support. Please reinstall iPhone Configuration Utility. You can download iPhone Configuration Utility from https://www.apple.com/support/iphone/business/
The problem is, I already tried to remove iTunes and the iPhone Configuration Utility and yet, the...
Read moreI am receiving error when trying to deploy a portable app so I can run it from my USB. The error is stating:
Xenocode Virtual Desktop: The application must be run from a removable storage device. Please contact your system administrator for assistant.
By the way, this occur on my Xenocode Virtual Application Studio 2010. Can someone here help me on resolving this?
Read moreMy computer screen just goes blank each time I boot up. I have used an old power supply and a used hard disk that is in a good condition and had Windows 7 64-bit installed. All the other accessories are brand new. The computer turns on with no problem and everything in it like the fan seems to run efficiently but there is no display at all. I have even checked on the VGA card and it is perfectly working on other computers. What could the problem be? Please assist me fix this issue.
Read moreI have a new Mac computer. When buying it, I was told it has a wireless input device that uses a similar technology to that of Bluetooth. Of late, I have been trying to use Bluetooth on it, but I have not been able to. How do I find out whether my computer has Bluetooth? How do I activate Bluetooth on a Mac Computer? All help is appreciated.
Read moreI put my computer in a sleep or hibernate mode with internet connection for most of the time so that I don’t miss important software updates from the internet like antivirus update, but it has not been working out because I don’t get the updates when I put it back on. Does it mean that when a computer is in a sleep mode, it loses its connection to the internet and is there a way in which a computer can be hibernated without losing internet connections?
Read moreMy friend has been constantly putting his computer on a standby and hibernate mode. For a very very long time he has been doing this without any problems, but of late the computer has been very unstable and its speed has also reduced. He has been handling it with a lot of care and he is linking the slow speed and the instability of the computer to the fact that he has been hibernating it most of the time. The most disturbing question is whether placing a computer system on a standby and hibernation modes can render a computer...
Read moreI have a new computer and am also new in computers. My computer has been working perfectly well until recently when I was surfing the internet and software from one of the sites I was browsing in installed itself without my consent in my computer. Ever since this happened my computers settings keep changing and its speed has also reduced significantly. Which software could this be and what can I do to bring back my computer back to its normal status?
Read more
