Archive
My Dell laptop won’t go into a standby mode. The configuration is correct and all the settings are also perfect and are showing up in the control panel of the computer. Every time I try putting it in a standby mode it remains powered. What could be the problem with computer and which other settings can I check in the computer that is related to powering a computer to help in resolving this issue?
Read more
I have a Windows XP computer with a hard disk memory of 40GB. It is too slow for and the memory is also too small for the files I want to keep in it. It is also unable to run quite a number of applications. It also freezes a lot while playing MP4 video files. Is there a way in which I can make the computer work faster and also increase the memory to a bigger capacity?
Read more
My computer is Windows XP operated. I feel Windows XP is too obsolete and I want to upgrade it to Windows 8 and I don’t know how to go about it. What parameters should I consider while doing this without causing any problems to my computer? And are there hardware parts that I need to also need to change as I try to upgrade my computer to Windows 8 from Windows XP to help my computer function normally and efficiently? The computer has 2GB RAM, 320GB hard disk capacity, system 32-bit.  I desire to do this probably via internet...
Read more
My computer has a compact disk ROM that only plays CDs. I would be happier if it could also read other formats of DVDs. I have a feeling that there is a way in which enhancements can be made to suite the description of what I want. What can I do to enable my computer read DVDs too?  And is there any software that I can install to help my computer read DVDs? Thanks in advance.
Read more
The memory of my computer is full and I can no longer store any file in it. When looking at the hard disk’s memory, it does not show the properties of the drive. I want to format it, but I have never formatted any before, so I don’t know how to carry out the whole procedure. How can I format the computer and are there any problems that might arise as a result of formatting it?
Read more
I have a Nokia Lumia 535 Windows Phone bought recently and still in perfect condition.  I have saved some documents (pdf, word, excel, powerpoint etc.) from my computer.  The problem is that I can’t access any of these office docs (word, excel, PowerPoint) via the Nokia Lumia save for the pdf ones.  I have confirmed that these documents show on my SD card when I access them via the computer.  I have also backed up a few copies via OneDrive and realized that these show up too.  However, I can’t rely on this method since I have to set...
Read more
Help! I am trying to open any folder from my Start Menu but all just result to the error listed below:
Explorer.EXE
System call failed.
I'm running a Windows 7 PC and I recently set up some software on it. It was working fine last night but when I opened it today, the error just continuously appears when trying to open a folder. Can someone help?
Read more
Why am I receiving an error on Ebay while uploading items? It says, IAF Token supplied is invalid. I was unable to upload In Beta Version due to this error. I am running Windows 8 if this will help. I'll be very glad if someone here can help me fix this issue. Thanks.
Read more
Hi. I am more on gaming and I need to know if upgrading to GTX 1000 Series will be a better option. I've got GTX 680 SLI right now. I want to play games with 4K videos and games so please let me know if GTX 1000 Series is available now or just go with GTX 980?
Read more
I have many files with spaces and underscores in the file names which is acceptable by windows. But for an application i am using it cannot tolerate any spaces or special character in the file names. Hence, I am currently manually updating all the file names. But it looks like it is going to take a long time and hence wanted to check for help here. Can anybody share a script or batch file to read all the files in a folder and if the file name has space or special character those have to be removed. Thank you...
Read more
