Archive
I would like a create a document to the users but would like to retain a copyright mark and also watermark in the document. When the user opens the soft copy in the computer, the watermark should not be visible. This is for the only reason that the user reading should not ne affected. Let them have clear view of the manual when they are reading on screen. But, when the manual gets printed, it is a uncontrolled copy and I would like to print my custom watermark on all the pages. How to make watermark visible only in...
Read more
I am looking the reason to not able to encrypt and decrypt the files in windows operating system. Is there any specific reason behind that? What happens to the compression factor if the files are encrypted? Are there any loop holes or security threats in doing so. I was going through this topic in a blog on the other day but couldn't get a feel of it properly. Have any body have good knowledge on the same? Can you please take an example and explain the reason behind the question of not able to encrypt and compress the file...
Read more
I run virtual machines for various reasons and recently I was running windows XP on windows 7 dell laptop. I observed that the space on hard disk was too less and decided to clear some space. Now, I deleted multiple virtual machine images and I deleted also the folders containing them. The surprise fact was that even though I deleted multiple images and folders from my computer, the free space showing up didn't increase. I was expecting some 30 to 40 GB of free space! I thought this might b a static issue and restarted my PC once....
Read more
I have got a Jabra Bluetooth stereo headset and I use it to listen to music and attend calls. I have Nokia Lumia 730 mobile with which I use the Bluetooth headset. While listening to music if I get a call, the call connects automatically to the headset but after the call gets disconnected the music wont resume. I have to open my mobile and press the play button again! What is the setting that has to be set so that the music play resumes automatically after the call gets disconnected. One more thing is that this doesn't happen...
Read more
How to capture entire screen shot of current monitor view in one button press. I am working on image processing for optical character recognition. The computer continues to play a live video of 1020p with 30 frames per second. Whenever the user feels, he will hit a key on the keyboard. The key is a key on a keyboard and can be any thing and is configurable. I would like to know if it is possible to capture the screen as image in Cpp programming? How to run the program in background yet allow th user to watch the...
Read more
I have a comma separated file in the database and i need to detect some cases in some of the lines. The data os from a GPS receiver and there are many parameters such as latitude longitude velocity time number of satellite visible etc. Wherever the position (latitude and longitude) are zero it means it had lost the track and the position. I need to detect all those lines automatically and delete the entire line from the database. I know this kind of job is very easy in Perl but all my efforts went in vain. i am still...
Read more
Is there any drivers or software tools from Microsoft or any other sites which can disable all pop up permanently? My application runs by default immediately after system login and displays graphically various information being received serially from the test setup. The user don't have a keyboard or a mouse to control any thing. It is simply a read only monitor. Why do some times pop up comes related to display issues? The user had only option to restart when pop up comes as he cannot close the pop up. I am working on Windows embedded 7 operating system
Read more
I have installed strawberry Perl and am learning many Perl capabilities one at a time. I have written a few programs to explore the language and i am fairly confident about that now. i wanted to run one of the Perl script as an executable in windows command prompt. How to run a Perl script in the executable form in windows 7? I want to run very similar to how we run C executable in computers. Thank you for your help and guidance. How to generate Batch files and make it run, if possible? Or shall i try in...
Read more
My friend has given me a chance to explore surface 3 pro laptop as he has observed some problems related to over heating. I too tried to run many applications to see whether it is because of over load, but my observation turned out that even if I just browse internet for half an hour, the tablet gets very much hotter. It becomes difficult to hold. Why is that? What is the case when a 3D modelling software or a high graphic game is played? How to cool down and solve this problem?
Read more
I have the following setup. Apache/2.4.12 and is from Apache lounge. My current version of perl is 5.16.3 and also i have installed CGI for further processes. I am getting the above said error and don't know what it means and why it is happening. I have windows 32 bit OS and is working fine for other compilers. Am i doing something irrelevant? How to go through this error and continue working with my Perl. I have no problems in perl CGI scripts and they all work fine. Any suggestions are welcome. Please let me know if i have...
Read more
