Archive
What is the principal advantage of using address multiplexing with DRAM memory? Which of the following best describes nonvolatile memory? A nonvolatile type of memory that can be programmed and erased in sectors, rather than one byte at a time is? Select the best description of read-only memory (ROM). Which of the following RAM timing parameters determine(s) its operating speed?
Read moreWhat is LED technology, and what are HD and Full HD. Can we use the web browser on Smart LED TV? What is pixels quality and how can we find pixels quality? How many ports are available in LED TV? Which is the best quality in LED technology? How can we check?
Read moreWe have heard that the greater part of the Computer Notebooks now days are 64 bit Architectural. What is the fundamental importance of 64 bit Architectural Systems and what are their Advantages and Disadvantages. Why they are called 64 bit? Should I remain with 32bit or upgrade to 64bit? Are there any systems which are both 32-64bit?
Read moreNTR remains for New Technology Report, however what considers reportable? Why are NTRs essential to NASA? So am I obliged submitting NTRs? Shouldn't NASA's new innovation which was paid for with citizen dollars be made uninhibitedly accessible to the general population? Is there a correct time and wrong time to present a NTR? I need to give a paper about another innovation, would it be a good idea for me to still document NTR? I have the greater part of the data about the new innovation in a different record. Could I stack that into the...
Read moreIf some body needs to convert data on Microsoft Excel to sql, how do they go about this? What is the process of converting data to sql? What exactly is the difference between oracle and SQL? And which is better from job prospect? What is new software in excel? Please help...
Read moreHow would you substitute strings with sed? May I discover a few examples and allude to them in the substitution string? In the event that the string is 'old' and I run's/old/new', I get 'new old' as the outcome. I require 'new?' How would you supplant an example just on the off chance that it’s discovered, so that its executed faster?
Read moreHow it can be distinguished that somebody is utilizing ssh burrow as intermediary to associating with a VPN? Does additional gear expected to put the server to DMZ? In a VPN case would a dreadful client filter a server for open ports? Additionally, where can I download free VPN software?
Read moreHow do associations with a stunnel shift from SSL-VPN, if both are in progression on the same port 443, and both utilization SSL to scramble information? What is contrast between SSL-VPN and https movement setup with stunnel? At the point when SSL-VPN is blocked then how to keep secure searching on open wifi?
Read moreWhat is the most ideal approach to breaking down the appeal sent over SSL by portable application? It is redundant that the correspondence convention is Http/s so catching them with Burp/Zap/Fiddler or whatever other Http intermediary won't basically work, however by what means would we be able to get the movement to try and achieve the intermediary?
Read moreHuman genome took many years and cost tens of millions of dollars, today genome can be sequenced and digitized in minutes and at the cost of only a few hundred dollars, but the question is that “Can these results be delivered to your laptop on a USB stick and easily shared via the Internet”?
Read more
