Archive
I am looking for help in finding a way to restrict the user of excel to only edit the text in the cells but retain formatting. The user can update his name, correct spelling etc buy should not change background color or font size and font. How to control these? I am using Microsoft 2010 Excel in compatibility mode. If you can share me snapshots of the controls or at least the steps it will be of great help. One more information is that th contents what user enters will get updated automatically in other sheets of same work...
Read more
I have this strange issue in my mobile. Mobile is brand new and in order to install market application i need to have a google account but my existing google account is not working in the phone. I do not doubt on the internet because google search works.when i enter google username and password in the account information boxes, it simply says that the username and password do not match. I am quite sure of password but unable to solve this issue. I do not want to open another google account only for this reason
Read more
Doesn't Moto G mobile phone vulnerable to all viruses as it supports pen drive connections. Are there viruses for android Operating system already? What happens if a virus affected pen drive is connected to Moto G mobile phone? In general, when we insert virus infected memory cards to either android or windows mobiles will there be any side effects? How such a small operating system does takes care of itself without any antivirus built in? Thank you for your information.
Read more
I have to display images of an event in HTML page. I have got all the files on server already. I am using dream viewer to design the html file. How into sliders to a group of photos. The photos are of different size. How to make sliders work for different set of images of different sizes. How to set the window dynamic so that it adjusts itself for different images. Are there any image sliders which sense the mouse position and perform animations such as next or previous buttons? Thank you for replying.
Read more
What do DCC stands for? What is a plug and play monitor? How to find whether a monitor supports DCC or not? How to disable DCC in a monitor? How to configure the plug and play monitor? What are the benefits of plug and play monitor over conventional monitors? How to create custom resolution other than the one which is available by default from the OC and the graphics driver? Are there any utilities to perform the customization of required resolution?
Read more
I am looking to develop windows applications for windows phones. How to setup the compilers? Which is the integrated development environment for developing windows apps? Is there any readymade library kind of support available for apps development? Are the software used for development is free or comes with time limited versions. How to release apps to store? Are there any fees involved? How does purchasing app by the user credits amount to the developer account? It will be very useful if you can share all these information.
Read more
I have a single database file whose size is approximately 5.9 GB. Its 6 GB along with supporting files. I tried compressing it but it simply taking long time and didn't had more space left in C drive too. Right now my problem is that, I am able to copy the supporting files which are of small size but not the database file. How to copy big files into pen drive? Is there any limitation on the size of the file that can be copied to pen drive? I formatted the pen drive with full 14 GB available space...
Read more
How to recover the files deleted from pen drive. I had taken no backup but deleted it a absent mind and now I am regretting. I have read many posts online but very scared to try any of them because this might make the recovery option worse. Had anybody earlier extracted data from pen drive or hard disk after deleting it permanently? I also visited a few service centers, they said they can try but it is not guaranteed to extract the data, they might be able to extract some files but the charge they are quoting is too...
Read more
The screen of my old CRT monitor goes black all the time since the time I changed the resolution to higher one. I can see the initial Boot messages, and also the logo of windows in the beginning, but as soon as it logs in, the screen goes black and never recovers. Why not the processor does detect this? The only way is to hard shut down by holding the power button or to remove the supply of CPU. How to restore the old settings back? I do not have any other PCs other this old desktop. How to...
Read more
Is there any automated scripts or the settings in Microsoft power point to set the shape properties of background image in the slides? I have presentation done in Microsoft 2013 and want to set the back ground only to the size of the contents (such as Headlines and sub items, plots etc) and not beyond that. Now, I am doing it manually. How to detect the portion of the contents in slide and set back ground only to that section of slide alone?
Read more
