Archive
I am creating a template with college name and other information in header and footer section. I have to reuse the template in all further slide preparation. I am using Microsoft 2007 and would like to know the way to create the reusable template. How to create personal templates? How to set newly created template as default? Presently I am editing the old slides for new presentations to retain the header and footer as is. Is there a professional way of doing it?
Read more
I have a total of 12 sub projects in MS Project. I am using Windows 7 Operating System. How is snap shot tool useful in sharing the project with others? How to send only one subtask view for any person without sending all other files? How to free up dependencies of MPP? Can I create Master project under which all other tasks are there but yet still share only master project with other clients? How to create a static master project?
Read more
How to use imshow function in two or more windows of the same Matlab? How to detail image in one window and add that subplot in another image viewer. I need to add sections of one image into another imview of same project? How to accomplish this in Matlab? Also, if the user selects to save the image, then the code has to save the image along with the highlighted section extracted and detailed in jpg or png format. How to automatically open the save image in image viewer application?
Read more
How to select multiple rows in one instant? I am looking for a particular value such as R102 or C22 etc in th excel cells. If i find these values in any one of th cells i need to highlight the entire row in any color. I know about conditional formatting but how to find a formula which meets my requirement. The values can be present in multiple rows and if yes, all the rows have to be highlighted with same color. Similar operation for different keyword and different color. Can you all please help?
Read more
How to see whether the installed Matlab supports C program compiling? If I have installed Microsoft visual studio, does it mean that I already have a C compiler on my PC? How to link the C compiler in PC to Matlab so that the scripts can be written in C. Actually run programs written in C to run and perform along with Matlab. How to add C files to compile in Matlab window? How to view the results? What are the advanced ways of performing C and CPP compilation in Matlab? Guide to tutorials are welcome
Read more
Where the options for adding pencil shade effects for pictures are, designs and shapes present in Microsoft PowerPoint 2010? How to draw a custom shape and add pencil effects to it? What are the available effects similar to that? Can I add pencil effects to both built shapes and shapes drawn by myself? I have a huge collection of handmade shapes in MS Word. Can I import them into my slides after adding the pencil shade effects? Will display reliably in all other PowerPoint viewers only software?
Read more
I have my laptop with flickering monitor. It creates me lot of headache after usage of 2 -3 hours. How to fix the flickering? Where are the flickering settings in Laptop for the same? I remember the refresh rate setting in old CRT monitors. Is that concept still there in these LCDs? It was handy in the CRT monitors but unable to locate in my laptop. Presently I am ignoring it but over long term it might be an issue.
Read more
What is the optimum size I can do insert in Microsoft PowerPoint so that all the TVs and different projectors and laptops with different screens can reliably present good looking slides and nice experience for the end user. I cannot simply increase the quality of the image alone. I have to fix on the optimal option for the pixels, vertical and horizontal, of the image when used to display on full screen. I display only images and no text or tables will be there in slides. Thank you
Read more
I am looking for free software to capture screen in real time. Is there any free software which comes without ad or time limited version? The software should be able to save the files on its own and it should not ask me every time to save or to name the capture for instant. Can I also record video using screen capture along with the sound? I will not use it for any other purpose other than personal so looking only for free versions but have to be reliable, fast and smart in saving, interface and other sharing options....
Read more
How to fix the following issue? I have a Dell laptop with all the hardware intact until now. Recently, I observed that there is an issue with the function keys. Especially F1 to F5. I need to press them hard some times and some times have to even change the direction of press. I am managing it with on screen keyboard now. I do travel a lot and hence laptop is a compulsory requirement. Can this be a driver issue? I am yet to get an external keyboard to check, still, it doesn't help much. How to replace the...
Read more
