Archive
I have a wireless signal that is not reaching the intended clients in my area, I overhead about a wireless extender, what is the principle of operation? How does the extender differ from a repeater and at what distance within the signal range should in be located? Do the extender give a directional or a radial signal?
Read moreI have an online malware scan tool that identified a certain malware running on my browser, all attempts to scan the system using an antivirus have proved not helpful. How can I remove this malware? It keeps on injecting onto my browser while accessing the internet and I get pop ups that I have visited an infected site.
Read moreI had scheduled for a disk scan and the computer restarted and scanned for errors in DOS. however upon restarting the computer seems to have lost some files. How can I restore for the lost files ? Is there a software that get back the missing links and make them whole again? How long can this take ?
Read more
I have a Pentium 4 computer that was previously overheated and shut down, however after checking for loose connections on the processor, It was established that the heat sink was not as effective. is there a way that one can establish if the heat sink has a problem and rectify.? Do I need to change the heat sink?
Read moreI have a 32GB flash drive that I want to partition so that I can store sensitive files onto a smaller partition and lock it. is this possible? How would I partition the drive so that I can achieve a smaller partition of 4 GB for my personal files and encrypt this portion only?
Read moreI have an Html based website and I wanted to able to inter grate the CSS interface in the page, how can I achieve this? Is it possible to incorporate the html interface so that it can fully be compatible with CSS and how would this be achieved? I look forward to a positive response
Read moreI have Basero burner and I wanted to find out if it is possible to write a multi sessional disk, what would be the write speed to archive this? Does the multi sessional disk support further burning in windows system? Can you add files in a windows system? I have both Linux and windows systems
Read moreI have a card reader that is meant for internal connection in a desktop, when i plug it into the motherboard I get a message that the high speed device should be connected to the right port for USB 3.0. How can I know if a machine has 3.0 support and is there like a PCI usb that comes with 3.0 support?
Read moreI have data in a pivot table however, Im unable to summarize my data into days of the week and I have a list of date that I need to use to do this. Please assist on How I can program my data sheet to do this with ease. Is there a reference material that I can use?
Read moreI have used team viewer over the internet to access a remote computer however in my office I have a local network that I need to establish a network connection to my office mates to access their computers, can team viewer do this or do I need a server to assist? I have no clue
Read more
