Archive
I have a video file that needs to be converted to aac in a mac, since Im new to mac is there any converter that is available that I can use? Does iTunes offers such a download or do I get it from an independent party? would the quality reduce upon conversion
Read moreI have a large set of data and I heard about pivot tables, however I have no idea how to achieve this. How can I summarize my data sheet into tables and charts? I have over 1000 entries of data that needs to be analyzed for my research and needs to be done quick
Read moreI have a game that is operating on a higher GPU environment, is there a way that I can inter operate this in Linux and use in in a Linux environment? Is there a way that I can intergrate the GPU so that I can improve the performance for the Linux to support this?
Read moreI have a Linux mint 17 and wanted to install wine for windows and be able to run this on the Linux environment and operate the windows based soft wares. How can achieve this from terminal and is there a .exe like installer for the Linux hat I can use? Someone recommended this to be I have no idea
Read moreI have a shell script that works well in a windows environment and wanted to be able to use it in Linux, How can I achieve this in a windows environment? I need the script to operate some function in windows. Please help me achieve this, and offer an alternatives on how this can be achieved
Read moreI have a VLC version 2.0.6 that is installed in windows, how can I establish a remote control tool for using my phone for this version of VLC.? I want to be able to use my phone to control the applications for this at my comfort. How can I update my VLC in windows?
Read moreFrom a COM Interop point of view, which one is better to use? C# .NET(interopServices) or IDL in managing of COM+ interface? Is there anything that InteropServices have that isn't possible with an IDL or is there anything that IDL has that isn't possible with InteropServices? I'm asking about performance and feature differences.
Read more
How to adjust the color of a printer externally by hand. I need the printer to match the monitor, it doesn't make difference whether both of them are perfect.
Is there a way that you can print a test page, and then on a monitor adjust the color until it matches the printed version. After that when you print, it would do the opposite operation, so that it matches the monitor?
Read moreI'm developing Windows Phone 8.1 silverlight app for budget tracking and I want to check what were the expenses in a past month. Unfortunately WPF 8.1 doesn't have calendar control so I need to solve this problem differently. Any suggestions would be much appreciated!
Read moreI see everywhere to store all my family photos and data in a cloud like Amazon or Google. What happens in ten years if the place I was using for a cloud storage closed their doors. What protection would I have not to lose everything I had there? Or would it just all be gone?
Read more
