Archive
I'm in confusion as I have to get myself a new laptop but I'm not sure with which CPU should it come. I know there are intel and amd processors on the market but I'm not sure which one to choose. What are the differences between them and for what is each of them good or better?
Read more
I have a zip file that was sent to my bookkeeper. They keep telling me the file is corrupt and they can not open it  Is the a guaranteed way to zip a file so they can always open it? Or a program that I can suggest they use to open it?
Read more
I just added a Seagate 2T drive to my computer as a second drive. Everything loaded including the drivers. Now when I go to the drive map it only shows the first drive. I can not access the new drive at all or get it to show up in the list.
Read more
Does any software for integrated development for Ruby on Rails exists? I'm familiar with just ruby IDEs but is there any built especially for Rails? Is there maybe an IDE with some extensions for Ruby on Rails to help me develop Ruby on Rails applications? Also, I want to know what are the alternatives to my question?
Read more
I have a MacBook Pro from a coming years ago. When I turned it on tonight there was nothing on the screen but a big grey box. I have reset the computer and each time it keeps coming up the same way. Has any one had this happen and know how to fix it?
Read more
Smarthpones have the option to share internet connection with nearby devices. Is it possible to share a connection of mobile internet through pc so it can be used by multiple devices on the trip? If it is possible, which softwares do I need to install to be able to perform it?
Read more
I would like to hook my PS3 to my gaming computer but everything says I need a VPN connection. What is the best way to set this up to get the fastest speed for my games? What other connections do I need to get this up and running quickly?
Read more
I refilled my cartridges in my HP  PhotoSmart 5520 like the manual explains. I never had a problem with starting it back and printing right away. Now it says there are no ink cartridges in the printer? Is there a reset button I need to push to clear this up?
Read more
I get really bored with one game at a time playing. But it takes awhile to get one logged in. So I was trying to find a way to play more than one Steam game with out it crashing my computer. Or slowing down the other game I am playing.
Read more
I am really worried about what is wrong with my computer. After I do a complete shut down and wait for a few seconds. My computer will boot itself and come back on. I am really concerned about something shorting out and causing a fire. Would this because of a motherboard or hard drive?
Read more
