Archive
I have been looking for weeks and can not seem to find what I need. Is there a Youtube video downloader for Chrome? I was pretty sure that someone told me they had one. Any suggestions on how I can download video with Chrome? Or is it easier on another browser?
Read moreI do a lot of personal banking and work on my computer. So I need the safest browser to keep from getting hacked or identity theft. Is one browser safer than another when going to a online banks website? Can a browser give hackers access to my person files stored on the computer?
Read moreI am stumped on exactly what I am needing for this new class that I just started taking. Which one of these would be the correct answer for a config problem - What kind of installation do you want? Server configuration JEE configuration (EAR file) JEE configuration (WAR file) ?
Read moreI have been using my MAC Air for about a month now without turning it off. Is it ok if I have it go to sleep but not really turn it off? If my battery wears out will it cause the computer life to shorten? I leave the lid up but should it be closed?
Read moreI want to use my computer to record our band to upload our music quickly. We are a hard rock band with lots of drums and guitars. Can we get good sound recorded without a special sound card? What other ways can we record music to record quality with just our computer?
Read moreI finished upgrading one PC and used a power supply that was working. I literally just pulled it from one system and added it to this new one. Now I am not getting any power at all. Can these be damaged just by unplugging them? Is there a way to test them out of the computer?
Read moreI built my system last summer with what I thought was a strong power supply. I ended up needing to replace it with in a couple months. Now once again my system has died and I think it is the power supply. How can I keep from this going down every few months?
Read moreIf I replace my current mother board which I think is about to die. Do I need to reinstall windows after I install the motherboard? I really do not want to back up everything on my computer and reinstall everything. But if I need to I guess I really do not have much choice.
Read moreI have a HP Touchsmart that I think runs really slow. Is it possible to upgrade the RAM on this machine? Can you use regular memory like a PC or is there ones just for laptops? I would like to speed it up as fast as my PC. Is this possible on a laptop like this?
Read moreI was watching my screen after installing new memory on my new build and it does not look right. What gives you the most reliable count Windows Task Manager or Speccy? One is saying 666 and the other reports 1867. How do you get a the actual number to check out performance?
Read more
