Archive
I need to monitor my house right now while I am at work but do not have a security system installed. Can I save money and time by using my webcam on my laptop? Would it be  secure to leave it active for hours without having someone there to check on it?
Read more
I want to start using a webcam to connect with family online for the first time. But when searching for a webcam I came across articles about webcams being hacked. Is is possible for someone to be watching me with my webcam and I not even know it? How do you know if they are watching you?
Read more
I bought Norton Anti-Virus and installed.  I have tried restarting my computer, uninstalling and reinstalling the software, and also tried running to see if a virus is preventing me from installing with no luck.  Did I follow all the applicable steps?  Should I try purchasing another product and installing?  I hate to buy another product but I'm out of ideas for Norton.  Thank you.
Read more
I have a Lexmark laser that keeps giving me a error that says  remove paper from standard output bin. I have tried to research this error and can not find it listed anywhere.  I cleaned the machine inside and out. Replaced the toner and made sure it had paper. But nothing is making it go away? Any suggestions?
Read more
This may be a long shot but I am really starting to learn more about 3D printing. This will not be for a business but just to test out and start learning the basic of 3D printing. Does any have a recommendation for a 3D printer under $500 that works really well?
Read more
I spilled  a small amount of coffee on my trackpad but everything seemed to be working fine. Now a few days later my trackpad is skipping when trying to use it. If I turn off the trackpad everything else is fine. Can you replace just the trackpad or a way to fix this?
Read more
Hello all.  I have started using Google Chrome as my browser.  I used to use Explorer all the time, until I started noticing differences in loading and functionality.  For example, I will have a search bar for my email in Chrome but not in Explorer.  I am running on latest updates with a new desktop.  Any suggestions as to why this may be or do I just allow myself to continue using Chrome?  Thanks.
Read more
I just added BROGUE to my computer after a friend recommended it. I can not find a way to play it with my mouse.  It seems to want just wants  keyboard controls which is so old school. How can I move everything around with just my mouse and skip the keyboard?
Read more
I have had this Dell Studio laptop for awhile and now can not get into the BOIS. It keeps coming up saying I need a password? Is this set at the factory and shipped with one?  Will Dell have it recorded or did it come in the original paperwork that I threw away?
Read more
I have a older HP ProBook that I would like to add a Kingston 120 GB to. When I do it comes up and tells me there is no OS.  With Boot Drive Device Not Found.  Do I need to upgrade my BIOS first? Or is the Kingston having problems?
Read more
