Archive
Assume there are five people to whom tasks have to be allocated. I want one person to work on a task for complete day or until the task is complete whichever is earlier. How to define this requirement is MS project so that, first person will get to handle the task on Monday, the remaining task will be handled by the second person on Tuesday and so on? I have tried, but since the task almost gets over in two days, the other three persons are not getting the tasks only to be accomplished. What is the solution?
Read more
I have several m files and data files in a project. Now I want to rename the m files into standard specific name format which I have to compulsory follow. But, when I rename all the files the project is no longer executing well and I am getting following errors: System cannot find the path specified. I have restarted the PC, cleared all cache and recycle bin too for that matter. What might be the cause of this? The Matlab toolbox is fine because I do not see any errors in the old project still. Any solutions?
Read more
I am managing a very big project with multiple managers for specific task groups. I would like to assign one of the mangers to update the task status. How to set any one of the available several project managers as a manager with rights to update the task status? How to add multiple managers to one single project? What are the permission rights available? Adding the resources is easy thing. But I am worried more here about roles and their permissions.
Read more
I am trying to increase the speed of the functions I have implemented so that I can speed up the process. I have datasets in multiple files and of gigantic size. I am trying to find the pattern and hence it will definitely look more time consuming. With the assumption of little errors, what is the chance of minfunc function helping me in this regard? Are there any other functions in Matlab which helps in optimizing already optimized code? Thank you for your help.
Read more
I have installed team viewer in three of the PCs I have. All the PCs have latest Team viewer versions and one of them has Windows 8 OS. The other two are running on Windows 7. One of the Windows 7 PC performs better and is always up to the mark even during low speed of internet. I have a good connection speed and hence have not faced any bad internet speed as such. But in the other, the team viewer application slows down and takes seconds to load the full screen image? I share the same internet across...
Read more
I am using internet to download several files in computer running on Windows 7. Now, I have a requirement to jeep an eys on the size of the file being downloaded. I have experience in using three browsers namely Mozilla Firefox, internet explorer and Chrome. I an ll the three browsers there is no support to detect and control the files being downloaded. I simply want to set the criteria such as if the file size is more than 300 MB the file should not be downloaded automatically. How to perform this check? Are there any other browsers which...
Read more
I am trying to find the way to play a pair of videos or four of them at a time. I am trying to display video inside video. I am aware that Matlab allows loading and play .avi or more supported files. But for the requirement, I need to load multiple file at the times instant and make the video presentation. How to accomplish playing multiple video at different timeline? How to pause on or more videos while others are playing? How to do image effects of blurring and highlighting while playing videos in Matlab?
Read more
What are the steps to be followed to recover database? Where will be the database basically dropped into? I am still learning the database and I recently dropped a database with good number of shopping data I had created. Searching everywhere for the way to recover but all went in vain. Can anybody help me in recovering database for me? Will the pages be still on disk and I could run some file recovery software? Is it easy or I should consult a profession in case the dropped database is of paramount importance?
Read more
I have the role of Manger and I am trying to analyze the efficiency of tasks assignment and status of the tasks. If I select one individual task, what should I do to view the efforts of all associated put into that task in one view? Is there a way to create custom group so that I can view efficiency of selected associate in the entire project? What is work filed primarily used for? Does it have anything in store for my requirement? How to use work file?
Read more
I am using the MS Project and I am trying to take print out of the calendar with the tasks. I am trying to make all the tasks visible but I can notice that some of the cell data are missing. Is it a known issue while issuing print in MS project? Cannot I get all the tasks printed in one page with current view? What are the optimizations I can do to get all tasks in page printed? What is the best option in setting Layout view?
Read more
