Archive
I am just learning all the things in MS project and want your help in learning the things better. What is the way to add the activity? How to add status information to all the activities? How to issue print to the printer the current view I am looking? How to add risks to activities? What is the way to add approval and rejections? How to set email alerts to pending activities? What are the different available roles? Thank you for your help?
Read more
I am trying to develop alternative to collect the analytics of the shopping website. I would like to customize the details presented in Google analytics and give much more rich information to the vendor. Can I use Hadoop to retrieve and customize the data? How well is Hadoop in gathering required information? What are the abilities that the programmers of the Hadoop posess to get the customized data? The data can be browser experience of the customer. Thank you for your help.
Read more
I want to get the contents what the user enters in the form before he clicks on submit button. Can I use Ajax for the same? I want to process the contents and update the window next to the form before user sends the data. I want this ti happen in real time, I was thinking to use PHP and process the contents and update the window in server but I do not know how to take contents in real time without asking the user to perform a button click? Any help is highly appreciated.
Read more
I have a huge database of links of products of a superficial store. How to parse the HTML file using Perl language. I am writing a few scripts and testing the same. My main difficulty is in making the script simulate the click behavior. How to simulate that? Also, is there a way to send all the extracted and clicked links into printer? I want to create a report of all worked links so that both testing and report generation is automated? Is it possible to generate the PDF report of the same?
Read more
I want to check all the data in my android phone for security vulnerabilities. I have heard that I can execute tcpdump for a day or more and collect all the data. What are the third party software available for verification? How to view and verify the collected PCAP? How to identify the source of the alert if I indeed get one from the report? Can I identify the app which caused the alert? I can verify the files as I have Linux but don’t know how to proceed with this multiple unknown things.
Read more
I am a fresher in PHP programming and I am trying to use access feature. How to retrieve the data what user has entered in the HTML open window or box? How to check whether the given link is valid or not before attempting to open? How to open the link entered by the user? It can be an image, a song or a video. It may also be another folder. How to detect and inform the user about invalid path or file names?
Read more
After mounting a new version of PostGreSQL I did also the following updates. I couldn’t open any if theinstalled apps. So I shutdown the systems and started again but still I cannot open system preferences! How to change the admin to default whih was there before I installed the PostGreSQL? Can I recover the documents folder and other user account folders while still having PostGreSQL installed? The root folders are visible in command prompt but have restricted access. Kindly help me to correct my system.
Read more
I am working on a code to improve the performance in javafx. What are the best aspects of optimization early as possible in code development? How to make calls for every change committed in javafx? How to change it so that calls can be made once for each frame rather than for each change? How are events helpful in modifying the javafx code for code optimization? Can anyone guide me in generating an event for the same? Can I utilize java nodes for the purpose?
Read more
I am using Microsoft Project and I got this challenge in MS project. If I assume that I have five associates and I have to assign 5 tasks for them, what are the options I have? What is the best way to assign a task to an associate? Do there we have any standard algorithms to track the tasks and responsible associate? If I have to assign 1 task to all 5 shall I set 500% to that particular task? How to track individual performances then?
Read more
I am looking for your kind support in the following case. I have created a form in HTML which takes multiple numeric values from the user and also some conditions. Once user clicks the submit button, the data will be received by the server. What are the ways in which the server stores the data? How to interpret the data if multiple users are using the same form from different places but at the same time? Which programming language is better for the server data access and computation of result to be displayed to the user in return?
Read more
