Archive
I have forgotten my bios password is there a ware I can rest this to the default? what would be the default? My machine is a Dell Vostro laptop, I have tried removing the battery for a while but it wont just reset. How can I go about this? Will this loose some of my settings?
Read moreI have a Core i7 machine that stopped working and I found out that my processor had a problem and needs replacement. Can I downgrade a Core i7 into a core i3 processor? I want to make a swap but not sure if it will work, are the cores backward compatible?
Read moreI have a desktop computer that is heating up in the core processor, I want to make my fan operate at a slighter speed because of my ambient temperatures at this place are higher, is there a way that I an regulate this fan speed? I want to cool my core processor.
Read moreI have a host system in windows that is running linux on VP, is it possible to share the internet from the host machine to the Vp OS? The host internet uses a proxy server, do I also need to connect the proxy servers settings fro the host machine? Is there reduction in speeds for connection?
Read moreI have some icons for the up and down scrolling that I would like to be integrated in HTML how can I do this in the editor for HTML? Is it possible to import pictures into the editor customized? How can I make the images act like variables that can change? Do I need software for this?
Read moreI wanted to upgrade the cpu on my laptop and i was wondering which motherboard details and considerations do i need to check or take into consideration in order to acquire an upgrade of a new cpu for my laptop coz i saw an exact machine like mine only that it had high specs
Read moreHey guys, im using linux (ubuntu) and i was wondering if there is a way that i can set wine to use proxy server (linux server running squid) or wrap any wine application using a tcp socks wrappers like proxy chains or tsocks such that i can connect to the internet using the proxy server.
Read moreIs there anyway to use parts of a broken android phone like bluetooth module, accelerator, gps among others on an arduino project and if so how do i identify the parts on an android motherboard as in is there a database that i can use while doing this and also how to remove the parts
Read moreHi guys, i recently installed Google sketchup 2014 pro in linux ubuntu 14.04 and i wanted to access the plugins warehouse to install a plugin but it seems like every time it loads up it opens a link on my default browser to the extensions / plugins site. How can i make it load in the extension window and not the browser
Read morehey guys, i have a project in linux that requires the use of the virtual ports tun and tap. How can i use the virtual ports over a link that i have created between two computers such that it acts like an Ethernet connection between two computers on an network.
Read more
