Archive
I have an HP d2300 series with an efficient power supply of 300w, however over the times I have had several device upgrades and was worried about the load on the power supply. what is the maximum load in devices that i can connect to the power supply at a given time?
Read moreI have always wanted to buy a projector to increase the screen ration for viewing and gaming, however I have no idea what to look out for. What are some of the features and characteristics that I should be on the look out for? How can I tell a good projector from an average one in the market?
Read moreI have a 16 GB micro SD card that I recently bought that I have tried all avenues to format and will not format, I have tried Linux, and windows system and no success. I recently event tries to format using the disk utility software but no success. what is the next remedy? Or is this one completely ruined?
Read moreI have a Nokia Asha 206 that connects to my computer via Bluetooth but will not connect to the Nokia PC suit what could be the problem? How can I make this phone ne synchronized with the suite? Im using a current suite so I ruled out the possibility of the program having a problem. Ho can I trouble shoot for the phone without establishing a connection.
Read moreI have a Linux on a mini laptop and the Linux was corrupted so I need grub repair disk and I heard about the disk booting options from a USB deceive, how can I make such a disk and do I need any software? Can the disk be used along with other software to store while its a bootable disk.? I need to keep this for future use
Read moreI want a custom script that can extract data from various websites, which script would be able to handle the multiple environments and sites between PHP and java scripts.? I want a diverse script that can manage both the PHP or pearl based html web pages, and can work faster. Which is the best choice?
Read moreI have to wireless devices connected to a remote wifi and one of the on the handheld phone seems to pick even the lowest signal while the other misses out on the desktop via USB. How can I improve the gain on the USB device so that I can get a better signal like the wireless on the phone? is this achievable?
Read moreI have a portable hard drive that was formatted in Ext file system and some documents in store. I have since changed systems and use a widows based system, its it possible to read this system without formatting it. I want to be able to access my files while using a windows system.
Read moreNeed to convert the attached template from PHP to ASPX (.Net) format. I got thePHP download online but Im unable to convert to .net. How can I do this and what software do I need to achieve this? is there like a converter or something? I need the file urgently
Read moreI have an outlook smtp account and I have configured it using the default settings, however recently I had a problem where I only receive selective emails from a certain domain, what could be the problem? I have checked my domain black listing filter but this is not the problem? What filter could be running and stopping my incoming emails? How can I stop this?
Read more
