Archive
Hello, im an ICT officer on my attachment and i was wondering if someone could help me with any information regarding the best wireless networking device that i can use to transmit a wifi network on a small town 5km radius taking into account the building obstacles around and trees
Read moreI have a hotspot here at home and i wanted to block out some domains such that if they are detected, a message is sent to the respective user notifying them that the domain is blocked. Do you know of any software or setting that i can use to achieve this goal
Read moreI have a project that involves using the eingen faces for face recognition and im not really satisfied with the results when i do a face recognition using the algorithm and i was wondering if there was a better algorithm apart from the two algorithms or a better implementation using fisher face would do
Read moreI use both linux and windows on my laptop and my linux machine (ubuntu 14.04) failed to show up on the boot menu after i reinstalled/ upgraded my windows from windows 7 to windows 8.1. I ensured that i only formated the windows partition to avoid tampering with the linux partition. Please assist ...
Read moreI am currently looking into swapping my internal hard-drive. I am hearing about solid states for a while now but when I checked it is really limited in terms of size. The maximum size I can get for 256mb for my budget. That is really small. Is it really worth the money? I want to know the durability as well ?
Read more
I just made recent changes to my pc by adding a new sound card. Now when I restarted my pc, it failed to load windows, suggesting that recent hardware changes have been made to the PC and a repair is required. I have tried this option to no avail. What are my options? Should I format the PC?
I am trying to establish a wifi connection at work. What are the solutions available to be to make this happen? Also given that this is a work network, there are some issues in terms of accessibility. Some websites are currently blocked from access, will that be carried over to the wifi connection?
Read moreI just got myself a Sony Bravia Tv. I am very satisfied with it. I am facing a problem though when I am connecting an external hard drive to it for media streaming. The hard drive is not being detected. I have tried to connect other media devices such as a USB pendrive and a camera to no avail. How can I fix this issue? Should I return the T.V?
Read moreI am currently trying to hook up my playstation 3 to a 19 inch Asus monitor. The monitor is quite dated but it does support DVI and VGA. I have obtained HDMI-VGA cable and the monitor is failing to detect my playstation or is it the other way round? Can anyone advise me on the way forward?
Read moreI am a huge gamer and also a huge fan of the Xbox 360 controller. Given that I don’t have the budget to get myself an Xbox at the moment. I bought myself a controller and an Xbox PC receiver. I am currently gaming on windows 8, I have so far fail to make the receiver work. Can anyone help me with that? Is there any other way to connect the controller to windows?
Read more
