Archive
I have got a problem with my Modem, where I have to turn off and turn on every 2 hours for the internet connection. I have checked the IPCONFIG settings with and without internet but couldn’t find any difference. Will removing all third party firewall helps? Is it safe to disable windows firewall and retry? Shall I uninstall and reinstall Ethernet drivers? Shall I buy a modem and Ethernet cables and try again? Shall I do any changes in static or DHCP? If yes, what are the possible things I can do? Please help
Read moreI have a practice being followed here to stay connected to internet without disconnection. I need to lift the receiver of my home telephone and keep it aside. If I don't do that, the internet works fine but only till somebody gives a call to the landline. As soon as it starts ringing, the modem shows that link has failed and connects again. But this interruption, though less periodic, makes me unhappy whenever the phone rings. Also, if I list the phone, nobody can call our phone too. Is there any solution to this kind of typical problem faced...
Read moreI have a blue tooth Jabra street 2, Bluetooth headset and it comes with a nice battery backup. The only problem is that, when working on laptop, I want to connect the Bluetooth headset to both mobile and laptop. I mean I should be able to receive the calls s well as listen music from laptop. They say it can b connected up to two devices but in practical I am able to use it. Am I missing any step in the installation? Have anybody have indeed used the option successfully? If yes can you guide me too? Happy...
Read moreAs mentioned above, I have got two working Modems with me here and I would like to know if there is any scope for using two modems in parallel. I want to connect one modem to a Wi-Fi router. Another modem, in a different room but same home will be connected to the desktop computer. Is it possible? I need to buy a wire and a splitter and would like to confirm here myself once before spending money to buy the harness. Have anybody tried this already? Does it work? Doesn't it create any problem? Thank you for your...
Read moreI bought a new xiomi phone online and was exploring all the features. I observed one heart breaking thing happening in my new phone. Whenever I turn on 3G and download, use internet, the battery drains like water in a bucket with a big hole in the bottom. I can literally see battery percentage going down. I am not exaggerating but this is happening. Bit my co user days that it happens only during some time. But why should battery drain so drastically? Is that a battery problem? Or something is wrong in phone hardware?
Read moreI have dell Ultrabook laptop with good built in speakers. I used it very rarely and nowadays I have found a problem. Over a time I have found that the problem is repeatable. Straight to the point. When I start laptop and do not play any music for 20 minutes or more, I have to forget speakers in the laptop. If I play any video, only the video plays, but not its audio. But, if I start the laptop and play music immediately, then there won’t be any problem and I can hear to audio while checking video too....
Read moreI appreciate your time in helping me in inserting a newline character in the formula. Is it possible to display the result in two lines? The two lines will be the output of single formula in Excel. How to insert the line break in the formula? Does any formula exist for the requirement? If it is possible to insert new line character in between the two lines what is the way to do? Should I do some formatting of entire page before running the code? The two lines should be in the same cell but in two different lines...
Read moreScroll pad of my dell laptop heats up! Is the design so inefficient or is my system is faulty one. I ordered Dell laptop from dell store so I cannot doubt some duplicate laptop is the cause for the trouble I am facing. After some 20 minutes of usage, the scroll pad really heated up but works awesomely all the time. It is just the little overheating which is bugging me a lot. I have also done one observation where it happens that it cools down itself if I disable scroll pad for some time. Can anybody tell something...
Read moreDear friend, I am writing this question with great pain as I all time favorite desktop computer has started troubling me in my exam time only. It is good thing because of the fact that I won’t play games, but it is also troubling because, whenever I start to study I think about computer. I took it to service person also. He said, he wants to install new OS for which he needs to format my hard disk. I cannot agree because I have only import and documents, videos and some college materials in C drive. Can anybody help...
Read moreI have a monitor with speakers built in here at my work place. I always use earphones but on weekends and on holidays I always prefer hearing from speakers. So, whenever I plan to use speakers to listen to music, I feel like the volume from the speakers is low. It is so low that sometime I think the speakers have gone bad. Why does one give speakers with such a low volume? Are there any settings I can do in PC to increase the volume in speakers? It is very embarrassing to see unable to even solve a...
Read more
