Archive
I currently own a Dell inspiron n5110 2010 edition. Due to a clogged up system, I proceeded to format the laptop. Due to the formatting all the proprietary programs on the laptop have been removed. I am facing issues with the inboard webcam. I have tried to look for the driver, to no avail. Can anyone help me with this please?
Read moreI am currently faced with a connection issue. Even though I have a Wi-Fi connection, the coverage is not of the same quality throughout my house. I am currently looking into extending my wired connection. I would like to know the difference between an Ethernet switch and a splitter. Also, I would like to know what the effect on my internet speed and quality is.
Read moreI just managed to obtain an upgrade to fibre optics internet connection through my local ISP. Given that I have a large space to be covered, I am currently facing issues in terms of Wifi connectivity. Can anyone propose any solution to this particular problem? Also all rooms are separated by concrete walls, does this have any incidence on the quality of Wifi connections?
Read more
I am currently looking into putting together my own pc. Given that I am planning to construct a gaming system, the processing power will be very high. Given this setup, I want to have a perfect cooling system. In the past I have installed a few fans and found that it was not very effective. Can anyone give me alternatives? I heard water cooling was very effective, can I have a walkthrough?
Read moreI have a 80Gb solid state desktop drive that started to behave differently after a blackout, It is not as fast as it was when it comes to saving up my contents and this worries me. How can I rectify this situation and do I need a diagnosis software to run on this drive?
Read moreHello! Please help me with the following:
I have a table dle_post id autor date short_story full_story xfields title descr
How can I get the piece of code from full_story and change it for mine? For example I need to change <img border=”0” to <img
Also for example I have news under ID 1 to 1000 and I need to set date in the same field like that
one value for 1 to 100, the other one for 101 to 200 and etc. How can I do that?
Read moreIm a frequent web browser and I think I may have gotten a malware into my Samsung phone, is there a ware that I can clean my phone without the risk of loosing my data? I have tried installing antivirus but it will not finish to install, I think that the virus is blocking the software, How can I go about this to prevent such a malware again?
Read moreIm new to python even though I find it easy to run and operate, Im having problems compiling in Python. How can I go about this? Is there a way I can get to integrate python and java so as to use a multiplex environment? How can this be achieved, Im hoping that someone can help me on this
Read moreIm connected to a robust network running a 2 gateway server for mail and for internet, How can I activated the DCPHP service to allow automatic addressing of my IP to match both the file and the web service? Is there a way to custom my server to assign IP addresses from same submask? I want all the computers to automatically register the primary and the secondary DNS servers upon which the to services run
Read moreI am trying to run a 32 Bit program compiled on Windows 7 PC using VS2012/C++/OpenCV2.4.9 on a Windows XP PC and I get the following error box after executing the .exe on the WinXP PC. The procedure entry point GetTickCount64 count not be located in the dynamic link library KERNEL32.dll."
