Archive
I have images on cancer and would like to write the Image code sequencing to enable it to identify the stages of cancerous cells form other photos, How can I achieve this? what is the nature of this code? is it Java, C# or a simple line command? where can this code be found?
Read moreIm trying to install team view in Linux mint, I have already downloaded the debian version, however it pops up a missing dependency 'libjpeg62' and therefore cannot proceed to install the software how can I get this dependency? is there I way I can get a software that also uses this dependency and therefore install it along with it? which would this be?
Read moreI m aware that one can make a video call in skype over to a computer but can one setup a conference call from the phone over s skype network? what is the minimum requirements that I would need for a phone in oder to support skype conference calls? I need a portable link for video calls and the office
Read moreI want to learn how to write programs using either C# or C++ with an intent of integrating Java based applications for mobile devices, which is the most suitable programming language that integrates the Java easily? what are some of the limitations of using it? Is there a compatibility in its operation with Java?
Read moreDo tablets support open GL for graphics? Can I use a tabled to run some services in the case of a client computer to substitute for a Pc in the network? How effective is running host services from a tablet in terms of performance and suitability in a remote office setup.? Im trying to avoid getting another PC machine for this so I need an assessment
Read moreHi! I have a task to develop an application with face recognition. Application should be checking size, form and color of the face and pick a haircut for the face. Mostly the problem is that the application should first find face in uploaded picture. I don't know even where to start. I couldn't find that much information in internet about this subject. Please advise.
Read moreHi! My question is related to the process of getting video from IP camera. I know for example that with WEB camera with WDM driver you can get a pointer to the buffer with the image by constructing the corresponding graph with filter SampleGrabber, but with IP camera I have no idea how to access video or each frame. If somebody knows please advise how to use cameras with TCP, UDP protocols.
Read moreHello! Please help! I am trying to upload database from old computer to the new one and I see some weird error that I haven't seen before: Error 602: Could not find row in sysindex for database ID 7, object ID 1, index ID 1. Run DBCC CHECKTABLE on sysindexes. What does this mean? what is DBCC CHECKTABLE? How to fix it? Thank you in advance
Read moreI have an APC UPS that I use as a backup for my desktop computer, I have connected this to a power source but it still blinks as if the power is out, what could be the problem? I have checked the cable for loose connections but no success. Is there any diagnosis that I can do to establish this fault?
Read moreI have a desktop printer that refuses to print, I have made several attempts to restart the computer and even the print service but still will not print. How make the printer to print? the printer displays in the device manager so its not a connection problem, is there any setting to that effect that can make a printer not to print?
Read more
