Archive
I have a desktop computer that I would wish to install Ubuntu along with windows 7, the problem is whenever I install Linux the windows will not display on booting and when I repair, the Linux will not show. How can I make the two to exist at the boot menu? Is this possible and how can I do this.?
Read more
Hi! I am having troubles with CS5 since some time ago. Now when I open picture I can see it only in layers or when I move it, otherwise I can see only gray picture. Everything was really good till some guy came to fix my computer, he did something and since then it works only like that. I reinstalled it twice, nothing happened, please help me what could it be.
Read more
I have a 80GB hard disk that responds slowly when copying, How can I improve on its speed? I have tried disk defrag mentation and checked for errors but still the access speeds are very low. It takes longer for it to copy a small file that I feel it should have taken a shorter while. can this be improved?
Read more
Im familiar with the pinging of an Ip address in windows to establish communication of an IP address, however I can not seem to get this in linux, how ca I do this? Is there like an independent software that I can use that can do this in Linux? otherwise how can I use the terminal to achieve this?
Read more
How can I update my Firefox in Linux mint? is there a download that I can get and install over in Linux? I have no idea how to update software in Linux environment? Is there any other browser available for Linux other than Firefox and how can I install this? How can I update this in the terminal command?
Read more
I have a desktop that was just working fine, however recently it developed a problem and shuts down upon diagnosis I realized that it was overheating. what could be the problem? I can see from the status diagnosis that the fan is just working fine so I ruled out the fan, can any other thing cause the computer to overheat rather than the fan?
Read more
I have a samsung drive that was just fine and recently is selective in reading the disks, I cannot read the contents on some DVDs that seem to be working when placed in other computers, what could be the problem? I have tried to clean the DVD with a cleaner but still no results. Is there a setting that might have changed this?
Read more
I have a Dell computer that was working fine, however upon installing a certain software the computer request a restart and now will not boot, how can I restore this? I cannot get the computer to remove the software and I have no idea how to go about this. Is there a way that I can get the computer to restore without booting?
Read more
I recently upgraded to the new avast internet security and the problem is the computer that has been sharing the internet now cannot establish an internet connection, what could be the problem? Can this be rectified or should i downgrade to the normal avast.? I have tried to check for the antivirus firewall but cannot find any service related to the ICS.
Read more
How can I wake up a remote computer using wake up packets? Can Do I need to run special command to wake up the computer from sleep? I want to be able to stream less connect to my computer despite the power saving measures that are in place when its idle.
Read more
