Archive
I was running the 'sudo apt update' command when the connection was interrupted, now an error that my dependencies are broken keeps showing up, how can I repair for the broken dependencies and do I have to do this as a root user or just a normals user? what is the way to go about this in terminal?
Read more
Hi! Right now I have my DVD player connected to PC via standard 100 Mb cable using Nero Media Home 4 and the picture is beautiful, but the problem is that this cable goes through the whole apartment which is not comfortable for me. So I was thinking to buy the router to accommodate wireless connection but I am not really good in that so I would appreciate some advice.
Read more
I have used Photoshop all my life and I have a mac desktop in my office and Im unable to determine how I can continue with Photoshop in Mac, is there an equivalent photo edit in mac that can match up to Photoshop and where can I get this? Im new to the mac so I find most things strange.
Read more
I have a cabled and wireless internet ISPs and wanted to know how best I can build a redundancy network. Is it better to split the services onto the various topologies or do I use a multi gateway system to access the internet from ny network? which one would give a quick response and high efficiency in a network of 20 active computers?
Read more
I wanted to make find out if the new I pad6 supports ftp service that can enable easy sharing of photos, movies etc? Do you need an application for this? what wold be the ideal application that can support this including the authentification service that can enable a secure log in?
Read more
How can I run as a root user in Ubuntu? I have to install some software dependencies but the system keeps telling me that Im not a root user, what is the command for running this in terminal and once running as a root user can I delete some directories in the sys folder? I want to change the directory of the files.
Read more
My skype cannot establish an internet connection what could be the problem? I have cleared my firewall for internet connection for skype and I have got the ports to route the internet from the default internet settings for the system, is there a specific port number for skype connections? what might that port number be?
Read more
Hi! I know how to setup password in the beginning when you make new wi-fi connection, but I forgot to do it and now when I need it finally to have password I don't know where to put it. Router Dlink 300, Wi-Fi connection is the most simple, OS Windows 8. Thank you in advance for your assistance.
Read more
I have a wireless connection that I managed to establish a connection, however Im unable to connect the computer to the internet because the 'DNS Server is not responding' any way I ca get through this? I have tried to run a network diagnosis but still will not work., is there any setting that I need?
Read more
Hi everybody! I have router Huawei HG8245T, it has 4 LAN ports but only lan 1 is working, 2,3,4 are not. I needed to connect TV, I put cable to lan 1 everything was good, but when I tried others there was no connection. I need TV and PC to have internet, may be there is something in settings?
Read more
