Archive
I have a USB wireless adapter and i have been trying to establish a connection to a wireless secured network on WPA and keep on getting an error message? I have the right password but the connection still does not go through, what else could be the problem? Can it be rectified?
Read more
Hi! I need to copy table with a lot of columns in SQL Database (mdf file), only structure without data and assign a new name to it. New table will have the same amount of columns only 2 of them will have different data types. Connected my database to SQL Server Management Tools but couldn't find an option of copying it. Please help.
Read more
Hi! Problem showed up with Cinema 4D R12, everything was perfect till it stopped working, it simply doesn't run. I double click on the icon, it appears for 2 seconds in task manager and then disappears. I've tried versions from R11 to R15 and none was workinh, tried to run as administrator, nothing as well. Can't understand where is the problem.
Read more
Hello! I deleted accidentally archive with a lot of pictures that I really need. I tried to recover it with many different programs, the interesting part is that some of the programs didn't find anything, some found but all photos were damaged, only half, one program found only 5 out of n number, but they were in perfect condition. So I need an advice which software for that would be the best one.
Read more
Hi! Problem is that I noticed that photos from my camera are duplicated in folders in windows 7, I don;t know if this is the issue of OS. I wanted to delete them but then I noticed that those duplicates bigger than originals 2-3 times. I don't know if that is because the quality is better or something else so I decided to ask
Read more
I have a windows operating system that has lost many of my files, How can I schedule the operating system to do a file scan to ensure that the missing files are restored? How effective is the file restoration from the scan? Can I be guaranteed of getting all my missing files?
Read more
How can I create a 3D printable file format from AutoCAD? Do I need to install some kind of format? Is it possible to have a print preview in 3D for a 3D modeling in inventor? What is the best CAD design software for 3D that suite rendering too and what is the price?
Read more
Hi! I need two windows to be active on two monitors. For example, I play game in my laptop and in the monitor that connected there is a movie going on, so when I try to pause the movie with a mouse the window with game stops being active. So is there any way to prevent it?
Read more
Hi! Battery in my Apple keyboard started to last only 2 weeks when before it could be months. Also I have an issue with letter "T" uppercase, left Shift+T doesn't work, to make uppercase T I have to use only right Shift+T.  I cleaned keyboard recently, but after that I checked it, dried and everything should be fine. What can be the problem?
Read more
Hi! I have printer Brother DCP-330C , 2 weeks ago it started to show error "Unable to unit.51", I didn't use printer for those 2 weeks, but when I started it didn't work showing the same error. I reinstalled the drivers, disassembled the printer, checked is had paper jam (didn't have), ink, everything is good, I have no idea what is the issue.
Read more
