Archive
Hi! I connected my new projector to my laptop but the picture appears on the board with red color, so white font for example looks pink and the rest also has some red color in it. I checked the menu, letters were showing with regular white, so there is nothing bad with projector I assume. I reinstalled drivers and everything, still the same.
Read more
Hi! i bought recently Xbox One and now I need to connect it to my monitor philips 227el. At first I was using HDMI - DVI but it didn't have sound, then I bought HDMI - VGA and separate output for sound, but now monitor shows message that there is no video signal. After many many attempts it finally showed picture for 10 seconds and then again no signal. Please advise.
Read more
I have a sensitive file that I was saving when the power went out, How can I retrive my file's contents ? the though of starting again is just too much, Is there a possibility of the word saving internally or do I need to run a software? What would be the software to use for this?
Read more
I have to ask if it possible that I can format my disk and be able to support my existing NTFS files intact. How can I achieve this and which file system is better? How can I open and view the Linux files from the windows computer? Is it safe?
Read more
I had a USB device that ws working and after trying to save a file wont work, How can I retrieve my files from there? is there a software that can retrieve my files and where can I get such a software? What is the accurcy of retrieval of such a software and is it possible just to select a certain file name while retrieving
Read more
Hello! I need to extend RAM on my computer and I was thinking to buy 1 RAM DIMM 4096Mb DDR3 AMD 1333MHz additionally to 2 that I already have (DIMM 2048Mb Samsung 1333MHz), but I have doubts that in this case it will work in single channel mode which is worse than dual channel mode. So may be I should buy 2 pieces of DIMM 2048Mb DDR3 Patriot 1600MHz which will be more expensive?
Read more
Hello! I have an application with database which works perfectly when doesn't have big list of products, but when we add more the system starts to slow down. I need an application to check how processes of our database affect CPU and RAM because we will increase the list of products and I need the application to work really fast, so if you know some utilities like that, please share.
Read more
Hi! My problem is with CPU, the usage in Task Manager shows 100% when playing games or using office.. I tries to close heavy programs in task manager, didn't help. Motherboard Gigabyte 8LD533 1.x, CPU Intel(R) Pentium(R) 4 CPU 2.40GHz. I tried to install INTEL 02 CELERON 1.80HZ/128/400/1.75V but still CPU 100%. Will appreciate your help.
Read more
This year I decided to get myself a new mobile phone. I am currently hesitating between the new iPhone and the latest Samsung flagships. I heard that both these devices possess fingerprint scanners. It can be used for unlocking the mobile phone and it is specific to the user. I was wondering what the other application of this technology are. I read online that these scanners can be used to validate payments online or authenticate access on certain sites. Can anyone elaborate?
Read more
Are viruses menace really present on mobiles? How can my phone be contaminated by a virus? Recently I download a mobile antivirus from Avira. After a few days of usage, I experienced a huge decrease in the performance of my mobile. How can a mobile application affect processing speed? Are mobile Antiviruses necessary?
Read more
