Archive
I am thinking of investing in a smartwatch. But besides being completely connected to my phone, I would like primarily to use my smartwatch as a fitness and sleep monitor. I heard that the Moto 360 is a good choice but in terms of fitness monitoring, it has some major flaws. Can anyone elaborate? I heard that Microsoft produced a similar device with better results.
Read moreI am thinking to invest into a new PC this year. I am looking into the specs and noticed a novelty this year. What is an SSD hard drive? Can anyone tell me what makes the difference in performance and also price? Is it possible for me to have a pc with both a normal and an SSD hard drive on board? I have seen similar configuration on Alienware systems.
Read more
I have a majority of my work mails on the outlook/Hotmail server for a while now. Can anyone give me a fair comparison in terms of performance between outlook and other mail clients? I would like to access the contents of my outlook from my Gmail. Is that possible? Will that cause any loss of data?
Since I like to keep my pc clean. I regularly uninstall idle apps. At the same time, I try to keep my hard disk as healthy as possible. I heard that defragmenting from time to time is highly recommend for every PC. Can anyone tell me how to defragment? Also I heard that defragmenting can be done by third party apps as well. How can I fix bad sectors if detected on my hard drive?
Read moreI recently purchased a second hard PS3. Everything was working just fine until I applied the latest firmware update. Now, when I insert a Blu-ray, it is no longer detected by the system. Both games and films are no longer being detected. Also, each time I restart the system, I get an error message saying that the hard disk might be corrupted. How can I fix this?
Read moreI have been facing major privacy issues with my facebook account lately. Can anyone indicate to me the way to delete my facebook account completely? Also I would like to have a copy of all of the data published throughout the years on my wall. Is that possible? Can the same procedure be applied for other social media sites?
Read moreHi! I need to monitor HDD/SDD raids on the server, SMART errors and etc. I have LSI00331 (LSI Logic MegaRAID SAS 9271-8i KIT), OS Windows Server 2012 std, for that LSI offers only its utility MegaRAID Storage Manager, but with that one I can only check if it is online or not so may be you can advise something else?
Read moreHello all! Please help to setup ILO or IPMI on HP Proliant DL160 G6. There is no OS there yet, so my question is basically how to setup it without OS? Is it possible? DO you have to pay for those interfaces and if yes, then how and where I can get them?
Read moreHi! I have problems with hibernation, it works time to time, not always which bothers me a lot. For example, if I press the button 2-3 time only after that it goes to hibernation and doesn't come back easily, just showing ACER picture. Sometimes pushing power button couple of times helps me. My friend told me that the problem could be in installed intel rapid technology. Laptop ACER v3-772g.
Read moreHi everybody! Please advise how to install and launch programs on Windows Server 2012 R2 x64 Datacenter, because when I tried to do it, it showed following error:
Aplication launch error
Current application compatible only with such operation systen:
Windows xp 32 bit
Windows xp 64 bit
Windows Vista 32 bit
Windows Vista 64 bit
Windows 7 32...
