Archive
I want to automate changing the repeat interval of keys. Presently I am doing it on login every time. But it goes back to default and hence I have to set it on next time log in. Which is the registry in the system which holds the value of repeat rate? Can I change the registry key using some kind of C program? Do I need to also use batch file to run automatically on startup and change the keys repeat rate? Are there any other precautions I have to take while manually editing the registry? Can I edit...
Read moreMy questions are the following. I have a laptop and I enjoy using Bluetooth headset with it when working. Why do desktop do not come with Bluetooth. In other words, I would like to know if there is a way to make desktops, including old ones, Bluetooth compatible. WiFi is so common nowadays. Also, I might be wrong. Are there PCs with WiFi and desktops already in market? I would like to get rid of Ethernet cables, modems and make it wireless and comfortable. Thank you for sharing the knowledge.
Read moreI am facing an interesting issue with my CPU at office. Whenever I remove the plugs from the socket and try to turn on the CPU, the CPU doesn't turn on. Then I called the service team. They came after a day and when they came and pressed the power button it simply powered on! I had to think whether I was really experiencing problem or not. This problem happened recently again when I had removed the plugs to move the table. The same sequence repeated. No matter how many times I press the button CPU didn't turn on...
Read morehave one DDR3 1333 MHz RAM and would like to upgrade the size RAM with another memory with 800 MHZ one. The processor is Intel i5 and is 2008 Make. Is there any problem in using the RAM of same size but different clock speed? Will the processor adapt for two different speeds and accept the RAM? Will there be any hardware problem arising because of different speed RAM? Are there settings in BIOS to indicate the size and other properties of RAM such as clock sped, type, Maximum supported frequency etc
Read moreI dropped a Nokia Lumia mobile down on to the hard floor when it was on. It fell down, but didn't switch off and was functioning normally as intended. But after that incident, I have observed peculiar issue with the touch screen. If I touch somewhere it senses the touch somewhere else! I could believe that this is because I dropped the phone but this touch issue doesn't happen all the time, also, if I lock and unlock the screen the issue disappears. So, my question is does this look like a hardware issue still or I can go...
Read moreI am working on a project with a team to detect license plate in the image, and recognize the characters (character extraction). The image will be the front view of the vehicle. The problem I am stuck in is with the Algorithms I am using. I am utilizing both linear discriminate analysis and PCA methods. In both, for some vehicles I am getting the stickers or labels the drivers stick to the car. Is there any algorithm other than the mentioned which is used widely? One typical problem again here is license plates have no discipline in fonts. The...
Read moreI had a computer DVD writer kept aside because it was spare and was unused. Now, I am thinking of using it too along with the existing DVD writer which is presently installed in the desktop. Have anybody tried this way? Can a DVD writer be placed outside on the table with the computer cables coming out if the CPU. I may sound strange but this kind of installation will help me saving space on my table as I can hide CPU somewhere below the table and stop using the installed DVD writer. Any...
Read moreI have desktop PC at my home. It is already 9 years old. Till now I have replaced SMPS 4 times. Recently when speaking with the computer repair person, he told me to change the mother board if I have to protect SMPS. As a electronics engineer I could only wonder why would somebody doubt on mother board? Is there a valid reason? Can a faulty mother board really cause trouble to SMPS? Given the fact that SMPS has failed 4 times I thought I should trust him. Please inform me if somebody has similar experience or knowledge on...
Read moreHow to save history log of opened windows and executed scripts in gnome? can i use gnome activity journal? How to use gnome activity journal to retrieve the list faithfully? I have skimmed through the gnome deployment guide. But unable to find out the reason for not able to retrieve the list. What is apparmor? Can I use it to save the opened windows in previous sessions? How to make use of apparmor? Anybody please share the sample code and steps to accomplish this.
Read moreI want to create a utility which performs the functions of dwm but not the way presently it is. When i press quit key, irrespective of unsaved files, opened and edited notes, the quit function kills all of them instantly. is there a way to apply a script or a wrapper to avoid killing entire tasks in one instant? When the user presses quit button, how to display the unsaved list of files to the user? atleast how to retrieve the list of files which are getting affected?
Read more
