Archive
Hi! I have a task, to read XML file from FTP server (data output in the table). My implementation is not the best: file is downloaded to hard drive and then it is read from given path, for example 'C:/something.xml'. Personally I don't like it, but I couldn't find better solution. I guess there should be options to save file to RAM and and then to read it from RAM, or may be directly from FTP. I will appreciate your opinion and advice.
Read moreHi! I forgot to move files from old desktop to new one and I have already deleted Windows.old folder. I haven't format disk yet, so I tried to find it with different programs, such as Recuva, but it simply did not see it in root of disc C, as if it was never there. Can you please some programs for that, better ones.
Read moreHello! I don't know how to make Mac OS 10.9.5 print using shared printer. Drivers have been installed for Canon MF4350D , MF3010. Printers connected to Windows 7, shared and have no passwords, everybody can print, there is no password, nothing. Only when it comes to Mac OS I try to print and it asks me for password and then document get stuck in the queue showing that it needs authentication. Please assist as I don't know even wherre I should start looking for the problem.
Read moreHello everyone!The situation is the following: there are about 200 computers in domain, but stations with Windows 8.1 can be visible only to 5 computers in the network. How to fix this issue? I've tried many things, nothing worked. The same situation with Windows 7, but priority goes to Windows 8. Thank you.
Read moreHi! I use application to share wi-fi from my laptop, but not all devices can connect. Laptops and tablets do not connect, my phone connected by only after I reinstalled the driver in laptop for wi-fi. I think it shares standarts 802.11b or 802.11g, the ones that devices cannot receive, but in this case I don't know what I should do, renew the driver? Please assist.
Read moreHi! I'm trying to import databases from Access into MS SQL Server 2012 via master of import in MS Access. The problem is that he doesn't offer me driver of Access in it. I installed office to the server, because I though it might help, but no result. Please advise what should I do to see Access driver there. Thank you.
Read moreHi! Is there any chance to install local server on IPad? Some application like xampp or some alternative? I have a small server application, developed on PHP, but I need it to work locally on IPad, may be even IPhone. I couldn't find any solution in internet so far. Thank you in advance.
Read moreHello! I need assistance, I'm trying to connect my TV to internet through Wi-Fi. TV SAMSUNG au 46 es5500w; router ASUS DSL-N12u; Wi-Fi - SAMSUNG WIS12ABGNX. TV sees the router but doesn't connect, everything is ok using LAN and other devices connect to Wi-Fi successfully. Where should I look for the problem? Thank you.
Read morePlease advise what books can be helpful for learning C# and I also need to refresh my JavaScript knowledge. I used to study it, but it was long time ago and right now I need to start working with it. For C# I need information mostly about classes, methods, etc to be able to develop for Windows Phone 8
Read moreHi! System doesn't turn off after I changed processor. Everything was successful, temperature is good, system works perfectly, but after pressing "Turn off computer" only monitor turns off, the rest keeps working. I only can restart system with power button but that's it. Configuration: Intel Core 2 Duo E7500, 2933MHz; motherboard: ECS G31T-M2. PLease advise.
Read more
