Archive
Hi, mouse Razer Deathadder 35G can't make straight line, it jumos every inch or so. The other one A4 TECH 740K has the same issue. What is interesting that the cheapest one Glaser X6-10D works perfectly. I reinstalled drivers, cleaned the mouse, changed mouse pads even, but still the same thing. I don't have touch pad, it's a PC. Thanks in advance for your help.
Read moreHi! Motherboard ASUS P4B533-Х starts working but actually doesn't work as the monitor stays black. I decided to change motherboard because the previous one did not support USB 2.0. With the new one I tried many options, please advice what can I do. Graphic card GV-N56X128D-P, CPU Intel Pentium 4 CPU 2.66 GHz, memory 2х512 Мб, Socket 478. Also the question: are socket 478 and 478B different ones?
Read moreHello! I need motherboard for i7 4790k, without anything special. It would be better if motherboard will be good for games, with good sound card, good network interface card. I am planning to start processing video files and keep plying video games, So please give me your advice. Thanks a lot.
Read moreMS Outlook 2010 started losing text is I send message with attachments. The person who received the message could see only attachment but the text field was empty. That started after I installed Windows 7 instead of Windows 8, but I am not sure if it's the problem. Also it takes a lot of time to send message with large attachment, 10-15 mins, I don't think it's normal as well.
Read moreI want to get tablet for me, but I can't choose which one would be better for me. I will need it mostly for studying, email and working with documents. I love apple products but I was thinking to change for Surface to try, so I need advice and professional opinion which one would be better for me. Thank you.
Read moreHI! I decided to disconnect one of my hard drives (I have 2) and forgot which one is with OS and disconnected the wrong one. After connected back, but what I can see is only black screen and "restart ctrl+alt+del". In BIOS computer can see only one hard drive, the one that I didn't touch, but if press F8 while starting system it has both. Please advise how to add one more hard drive to BIOS or should I do something else?
Read moreHello! I have a problem with time and date in my laptop, after starting windows it shows 01/01/2006 00:00 am. I change it all the times, but each time after restarting the system it goes back. It bothers me because I can't use any website unless I change date and time. I tried to change battery but it did not help, right now my solution is simply do not turn off laptop, but I need to fix it. Thank you
Read moreHi! Processor i7-3630qm (2.4) becomes really hot after some time of working. Laptop has Windows 7 x64, laptop is not really old, almost 2 years. Right after starting windows it is still ok, but after loading 3-4 programs like Chrome for example it reaches 200F! It seems like he works with maximum energy for each program. Please advise what can I do?
Read moreHi! I'm looking for new video card for gaming mostly and I need your opinion in which one is better. The choice stands between 2: ASUS GeForce GTX 560 925Mhz PCI-E 2.0 1024Mb 4200Mhz 256 bit 2xDVI Mini-HDMI HDCP or PowerColor Radeon HD 7790 1030Mhz PCI-E 3.0 1024Mb 6000Mhz 128 bit 2xDVI HDMI HDCP V2. Please also tell me why do you think each one is better.
Read moreHi! I bought Wi Fi extender for my house, the one that you have to plug to electrical outlet. I located it close to router at first and installed driver, everything was successful, but then I located it in the place that I actually needed it and it couldn't find signal from the router, even though it was not really far. I tried to plug it in every socket and it worked only in ones that are near router. I don't want to return it, may there is a way to fix it?
Read more
