Archive
Hello! My CD-ROM stopped reading data on any CD/DVD that I make and any other. I usually burn disks with Nero and it is ok, also it has no problems with erasing all data from disks, but when I try to check files on disk it says 0 files, but DVD player has no problems with it. Same thing happens to any other disk, not made by me. Please assist, thank you in advance.
Read more
Please help me to solve this issue. I bought web camera HP HD 3310 and after installation of all drivers and everything it won't work nowhere. Skype is telling me that the camera is being used by another program. Camera's microphone is working, but there is no video. Also when I did all the same in my laptop camera worked perfectly.
Read more
I try to create internet connection with PPPoE, but after login/password input i press Next and loads till the middle and then says something like "Sorry, but we have to restart your computer" and after system offers to send report to Microsoft and nothing more. The only thing that worked was installing Windows 7, but I want to go back to Win 8, so please advise what can I do?
Read more
Hi! I need to reinstall windows but when I tried to enter setup in BIOS it asked me for password. My laptop is pretty old and i have bought it from my friend, so I don't know which password should be there. I tried couple of samples that I found in forums but nothing worked. How can I change boot devices priority without entering setup? What can i do to unlock BIOS?
Read more
Hello! I want to watch movies from my laptop on my TV so i needed to find VGA - HDMI cable. I bought VGA - HDMI adapter that was in the MAC section (I don't know why), but when I put everything together I still couldn't make it work. My laptop detects the second screen, but usually when I used to do it with VGA - VGA cable my desktop was shown on TV, this time TV screen was black and I couldn't change it. Please assist.
Read more
On my Samsung GT-I8000 (OS Windows mobile 6.1pro) after each conversation (incoming or outgoing doesn't matter) says that phone is off and turns on airplane mode. I don't know where and how change it. I did drop my phone couple of times, but nothing broke and there was no water or anything.I would appreciate your help. Thank you.
Read more
Hello! I installed Windows 7 on my PC 4 days ago by myself and today tried to send some files via Bluetooth and couldn't.  Reinstalled driver for Bluetooth device, but still the same problem. Other device can see mine, but error occurs while trying to send files. Other programs, devices work perfectly so I thought it has nothing to do with windows. Please assist.
Read more
Hi !
My keyboard on Sony Vaio laptop started to print also the letters that are near the one that I want to print, for example 'l' with 'k' and 'f' with 'd', etc. When I turn on Caps Lock this problem disappears. I don't want to reinstall Windows as I can't backup all my files and I can't lose them too, so I would appreciate advice that doesn't involve new Windows. Thank you.
Read more
Hello!
My IPhone 4S stops charging after 65%. It happened first when I decided to charge it at 75% battery and nothing happened, so I wait until it goes to 0 and then charged, but after it reached 65% it basically stopped responding to cable. I reset it couple of times, but it didn't change anything. I used it till 0 again, but no result, still on 65%. Please advice what can I do.
Read more
My computer started to show me BSOD time to time. I can work the whole day without any problem and three times in a row show me BSOD and error code stop 0x00000101. Please advice what could be the problem, I have reinstalled windows already 2 times, first time from Windows 8 to Windows 7, but it did not help. The worst part is that you never know when it can happen.
Read more
