Archive
Hi! Touch ID stopped working on on my IPhone 5s couple of days ago. I did not do anything unusual, now it says "Failed , Unable to complete Touch ID setup.Please go back and try again." I have tried to reset it with two buttons, but even that did not help and I don't know any other way.
Read more
Hi !
I have HP m9400t desktop, I restarted it by pushing reset button and after that it won't start Windows. It keeps trying loading windows 7 but always goes back to the screen with options "Start Windows normally" and etc. It doesn't load with safe mode either.  Then I started PC recovery and after some test it showed me error code HD521-2W. How bad is that? Can I do something to fix it?
Read more
Hello! I have Sony Xperia Z2 and everything was good till I started to have issues with Wi-Fi connection.
While connecting to wi-fi network it drops after "Obtaining IP address", it tries to connect and then go again and again obtaining IP. I tried to reset it, then "Forget network" and connect again, it worked for some time, but after it stuck again. What else can I do? Thank you in advance.
Read more
How best can I restrict access to shared folder access by some apps? I try to run some apps with specific user access so as to restrict access to some shared folder that is accessed by apps for different business purposes. Due to recent security breach, I try to restrict access to this shared folder, but the apps stop running as required. What other ways can I use to secure the share folder?
Read more
Why if FreeAgent accounting software cash management feature not working on my system? I am using the FreeAgent accounting program to manage my business for four month now. Most of the features the vendor provides are working superbly, but the cash management feature seems to has some problem. The program has all the data it required but the cash functionality is grossly incorrect. How can I fix it?
Read more
What are the best security strategies to use against winlock virus? A system was recently attack by winlock virus which edit the shell and userinit in the system window registry thereby leading to system malfunctioning. In implementing a security measure against winlock virus, what is the major system vulnerability that winlock virus exploit?
Read more
How do I make ContentFull content management software search functionality to work? I have been trying to use the ContentFull business management app search features for days now without any tangible result, the soft search function supposed to be working but whenever I use it, it seem it Is not working as it supposed to be. How do I address this issue?
Read more
How possible is it that introducing certificates for mobile app would improve mobile security? Now that anybody can develop mobile app for various reasons and these apps are finding their way to the various app stores, how could introducing client certificate increase the security of mobile devices?
Read more
How do I make my browsing secure when am using public wi fi connection or networks? I recently found out that hen am in public using public networks (wi fi), window will put my connection in public thereby protecting some of my files, but this protection is really limited because someone was able to access my files while using the same public network. Is there any other ways to increase my privacy while using public networks?
Read more
What could be making my Samsung galaxy note to start rebooting after I install devise firmware? I got some firmware update on my Samsung galaxy note recently and I install the firmware, but after the installation the device starts to reboot whenever I open any app. How could I fix the problem?
Read more
