Archive
I have a laptop and a desktop which both will be connected together via router. is it possible that only laptop has good internet connection but not PC? I am getting speeds signicantly lower than what i am getting in laptop? What is wrong? is there a problem in the router? I am getting most of the failed packets in PC. laptop works as normal. Should i doubt on PC adapter? I am performing Ping 192.168.1.1 to estimate packet loss.
Read moreI am using windows 7 in virtual machine. Is there any issues in using windows update for OS installed in Virtual Machine? I am trying to enable the automatic update on but whenever i try to do, the internet page laods and take me into a help paeg of microsft where it says how to enable it. I know how to enable it but not how to solve this error. What are the other settings to be done to download updates from Windows 7. How to update internet explorer alone?
Read moreI am trying to clean up all the file history contents in Windows 8. I had done this earlier safely without any errors. Is there any reason for not completing the function in windows 8? How to avoid errors in and complete the File History removal successfully? I have rebooted the PC many a times but the problem still persists. Will event log help in this case? How to access event log? Is it possible to clear in case, a few of them using any other tools? Thank you for your help.
Read moreI am looking for a way to establish dial in connection automatically. I will keep the Modem on but the dial has to happen at the time i program. Is it possible to write accomplish this using scripts? Can the scripts run in windows 8 to automatically make a connection at the timed interval? What are the required software to run script automatically? What are the steps to be followed? can i turn off the modem after certain time of turning on? Please answer all my questions.
Read moreI have lost Wi-Fi connectivity for my laptop. I was trying to update the firmware recently. Now the problem i am facing is that when i turn on the Wi-Fi by ressing function key F2,the Wireless connection not even shows my Netgear connection. Wi-Fi is fine and it works with my mobile. In device manager following adapters are available Intel centrino wireless-N 1000 WAN miniport (IP) #2 Hyper-V Virtual Ethernet Adapter #1 to #4 Microsoft Network Adapter Multiplexor Driver What is the issue? Are there any utilities to detect whether the Wi-Fi adapters are functional? Where can i get...
Read moreI was traveling in bus and was carrying the laptop. I thought of using laptop and hence opened it and started to go through some help documents. The screen was super and fine till them. But due to a road block or something, I hit the laptop to the front seat. Suddenly entire display went off. I shut down the laptop. Later, at home I found that laptop was alright but some permanent black mark in lower bottom left. Can it be solved? Will the patch grow, I mean extend, become large in size? Is it safe to operate?
Read moreI have Moto G , bought it happily for great discount and in the beginning was little unhappy because of poor camera but got adjusted. Just I thought is okay. But, I recently have been observing that it has got an issue. When I enable GPS and start GPS navigation app, it says nothing but works flawlessly. But after some time, it gets hot like red. I do not feel that is normal. It makes me uncomfortable to hold it! Is it normal is my question? Are there any other users of Moto G with same issue? Rather I...
Read moreMy friend has broken his laptop's screen and now is under stress because he has huge valuable business data in laptop and is required urgently. I want to know, whether it is possible to use the laptop's in some mode, may be projector mode or slave mode and recover the data in the hard disk. Correct me if i am wrong, is it possible to connect one laptop with another via Ethernet cable or USB cable so that the data in the laptop can be copied securely. Is there any other alternatives? Or should I run to the service...
Read moreWe are working on algorithm development for voice recognition and are in process of analyzing various notes of test set. We have identified 30 voices. We will use them as our database. My straight question to the kind support group is, can I create the graphs directly using C program or C ++? We have good programmers in team. Presently they dump data into a text file. Then we manually copy paste them into excel and do the plotting activity. Your sincere help will improve our application. Next stage is to have dynamic database updating where this will be...
Read moreI have only used Microsoft excel during college days and now I really regret to have no expertise in the same. I have to enter a set of numbers, indeed they are quite a lot. All the numbers should be in ascending order. The difference between the numbers should be some times 0.5 and sometimes 0.44. It varies a lot. Presently I am doing it manually because I didn't studied topics on MS Excel. But, better late than never. I will put more efforts towards learning. Kindly give me support to start with.
Read more
