Archive
Can I connect two Bluetooth headphone devices to one iPhone 6 and accessing the same file at once? I need to connect two Bluetooth devices to my iPhone 6 so that I can listen to the same music on the two headphones. But when I connect the two devices, I cant listen to the same music. Why this is so and how can achieve it?
Read more
How do I pass values to an Extensible Markup Language (XML) file from shell script? I want to pass value to an XML file from shell script so as to replace values in some of the tag, but the results I have been getting is not what I intend. How do I use the replace command in the script? N:B the values to be pass are likely to change?
Read more
Why is Ruby not installing on my Laptop? I just started learning Ruby general purpose programming Language and installing it on my laptop is posing a lot of challenges. I have tried many implementations of Ruby and none seem to be working on my laptop. What implementation of Ruby can be installed without Xcode?
Read more
How fast is the new Nginx version 1. 7. 9. Release over the older version 1. 6. 2? Am trying to upgrade to the new Nginx 1. 7. 9 version, but I want to know if it worth the In term of throughput, is there increase in the throughput? Can the latency be reduce?
Read more
Can a stolen Mac be wiped with configured root and boot option password? A friend recently lost his Mac Laptop and activate find my Mac and he cant find the mac on the network. The mac Laptop was configured with root and boot option password. What might the thief done with the mac that prevents it from detection?
Read more
How can I recover a lost ruby file in my system? I recently found out that some of my ruby files are missing on my mac laptop and the mac started malfunctioning. Is there a way to recover the lost files without reinstalling the OS? Also, I tried using the recovery partition to recover the files but my recovery HD is not patched with my OS.
Read more
How can I remove a program file from incompatible app in Window 8.1? I tried to install Quickbook but the program won’t install because of compatibility issues, but when I check the task manager and the program is there. I tried to uninstall the program, but it was in the program list. Why is the prog file on the system when the prog didn’t install on the system?
Read more
How secure is Apple pay and Google wallet? With many merchants and stores accepting Apple pay and Google wallet, what should I be concerned with about using either of the two for payment? Can unauthorized transaction be performed with the two without the one using Google wallet or Apple pay knowing? How long are the data collected by the merchant stored on their server?
Read more
Why is the server not mapping any drive and printers? The group policy is not updating the workstation while the user account control is on and I have tried to log on continuously but the problem still remains. I have collected the group policy result to check if the policy setting is applied successfully and the event log. What other troubleshooting approach can I use to fix this problem?
Read more
Why is Gatekeeper preventing my installation, claiming certificate has expired? Recently, when I tried to install on my OS X mavericks, the gatekeeper is preventing the installation. I have verified the key chain and the Developer ID Certification Authority is current and trusted. What is the likely cause of the issue? How do I fix it?
Read more
