Archive
I work on a website and was recently uploading all the files to server as normal but I came to know that one has r more files were not uploaded successfully. I have given job to sync my entire local folder but, some of the files were unchanged. The filezilla reported no errors when I had uploaded. Only recently o found the issue. How to find these issues in the future? I am still a fresher and didn’t want my job to be at stake. I do verify uploaded files immediately after that but cannot check all the files...
Read more
this is not actually a problem but a question on a solution I have found that. I just want to understand what is happening in the back ground. Problem is that my computer didn't boot. Service person told to come after a day. But he later said that his hard disk is gone. Since I didn't had money for new in right that place, came back home. Just tried once installing Ubuntu. Set some extension as file system. I think ext3. And then inserted windows OS CD. The hard disk got detected, got formatted and now windows is running...
Read more
I don't want to share my Wi-Fi password. I have a net gear Wi-Fi router and would like not to jeopardize the security. But whenever I want to share internet for the guests, I have to enter password manually for wifi and then once they are done using it, I have to make their device forget my Wi-Fi network. This is awfully done for my security. I was wondering can I make my smart phone (Moto G, 1st edition) as my second router to which other users can connect. Still source of internet for Moto G has to...
Read more
My problem here is that the mobile restarts every time I open here maps. I am a Nokia Lumia proud user and always promoted the mobile to my friends and relatives. But, when I thought of using here maps, it started to gave problems. Earlier, l thought this is an issue of update. Might be it restarted to update the issue. But my assumptions were wrong and it happens most of the time. Whenever it doesn't restart, it simply hangs. I have to press back button long time and close the app. Have anybody too faced the same problem?...
Read more
I have a hardware unit which logs the values from a FPS receiver every second in some standard format. The logging happens in text file. Every time I want to see the data, I have to manually copy the columns one by one and paste it into MS Excel. And then use graph feature to analyze the results. I am a average knowledge of programming but, I am failing here completely. I want MSexcel to automatically read the text file which is being updated by the hardware unit. I know this is an interesting application yet powerful and difficult....
Read more
I am planning to enable reception of mails only from one user and block all the mails from all other email IDs. Is it possible to allow one and block all. I am aware of the fact that I can block the contacts individually, but problem is if I don't know the email ID itself, how could I ever block the mail IDs. My requirement is to allow only person's mail to be received by the system. All other spams, unwanted mails shouldn't even get into inbox. Please help.
Read more
I wanted to get exposure to Perl programming. So, started with some basics as depicted in Perl famous guide. Also, Wikipedia had some good references for learning Perl. It had step by step, lessons to learn Perl. But, now I am starting to lose confidence. Hence I want to sharpen mu talents more on Perl skills. Can anybody help me in finding the right way to get good Perl expertise? Any good books I can confidently follow? I am ready to put hard work but i only need a very good guide to start with.
Read more
I am creating a report based on the data present in excel file. I had taken snaps of the image in image grabber and pasted it in MS Word. Now, due to my bad luck, my supervisor wants the graph to be natural and not as a image. Also, the same thing with the tables. There are about 75 tables and entering all of them is a nightmare. Isn't there a way to load graphs of MS excel into Ms Word? Also help is required to import tables from MS Excel to MS word. Kudos.
Read more
Hi all, I have managed to run Windows XP on my 64 bit laptop with the help of VMware application. The operation is smooth and fine. The only problem is that the audio is not working. I cannot listen to any music. The laptop speaker is fine because it works when running Windows 8.1 latest OS. Is there a issue with the virtual machine I have created or it is just the minor limitation of VMware, since it is running on a 64 bit machine? Can anybody also suggest some audio drivers which are windows XP compatible?
Read more
I got this unique use case where I was supposed to copy certain number of rows from one master excel to a copy excel. I did it easily by selecting using mouse and pasting it. But, for my bad luck one of the data was in a rows which was after so many empty rows because of which I could not see it. So, I decided to write some logic to detect the last word in last row so that I can copy the data reliably. I cannot copy by doing ctrl A and ctrl C because, the...
Read more
