Archive
I am playing call of duty game in my laptop. Laptop is from Dell Inspiron series, i5 processor with 4 GB RAM. It has a turbo boost feature which makes processor increase clock speed during high performance requirement. What I have notices is that, whenever I play the game, after around 20-25 minutes I cannot even touch the part close to the fan. I am keeping it on a flat table and exhaust is not an issue. Is it normal for laptop get that much heated up? Is it okay if I continue playing on? Any other self measures...
Read moreI am looking to buy a laptop and this time I have decided to go with light weight and thin laptop available in the market, after full research on other forums and discussions, I believe I have made a right choice. I should try Apple laptop this time. My usage is as follows, some simulation software, C, CPP compilers, Keil software, adobe Photoshop, dream viewer and visual basic. Can anybody please help in suggesting the best laptop foe the above usage scenarios? I just need a minimal configuration which meets all these demands? Also, can someone share...
Read moreI have written nice programs MS excel using VBA. I want to protect the code and also copyright it so that my name will always be displayed. But, my question is will the user be able to see the results which is a computation done in VBA code if I set the document as read only? The users can enter creative data and find relevant results. Di, some creeks should be suitable. Most of the cells should be read only. And, lastly, VBA code should execute all the time. Is it a possible thing?
Read moreI have a stereo Bluetooth headset from Sony which I was using comfortably all the time. Last week, accidental I poured a lot of water on it. I was wearing it and during drinking water it happened. Now, due to this, it stopped playing music and the moment it happened I too turned it off. Now it’s only three days till now. I am reading lot of similar stuff happening to other mobiles and steps to do and so. But here I cannot remove the battery as it is not simply possible. How long should I wait before I...
Read moreHi guys, I am looking for software drivers for my new I2C connect device which acts as a master foe I2C connector. It is expected to detect as a serial port on laptop. But since I do not have drivers for it, I am wasting time. I tried downloading random firmware, forcefully defined connection as COM port but of little use. A few days back only I bought this module and it came with a CD. I do not have a CD reader here. I have no access to other PCs or else I would have copied it already....
Read moreHow to set the row size and column size? The size has to be big enough so that small children can easily work in excel. I have to create a excel assignments for children and it requires excel cells to be broad enough so that children can easily work on the cells and do basic exercises. My clear requirement is to set the default size of rows and columns as big one. Currently every time I open a new document, I have to manually set the row size for each and every child which is tiring. Can anybody suggest...
Read moreI am a fan of COM port since 90s. I have seen it all. I have seen how USB took over all keyboard and mouse connections, how PS/2 vanished all together. Floppy disk became history and long ribbons are uncommon to current generation. My typical concern is about COM port. All other interfaces vanished but COM port is still there in apple Mac laptop. I mean why do people still want to use serial port virtually. They use that USB to serial converter. Will COM port exist for further centuries?
Read moreI have a technical fest in our college for which I am planning to have a huge display rather than a simple passive banner. All the monitors will be independently connected to individual desktop computers. I want to use those to display events, statistics and live results and some videos while particular events are running. But I have no idea what software to use to display multiple windows as one. Can you guys please help me in finding the software for the same? Should they be connected via Ethernet? How to connect all the computers? How can they...
Read moreUrgent help needed. I had a full excel document sheet with several sensor data. After several calculations I had plotted all of them in Excel. Due to power loss, the Computer turned off. But after turning on the computer what I can see is only a zero sized file. It is totally gone. The size was 2 mega bytes. I searched in temp folder but I could get the file. I cannot imagine redoing all the calculations as it takes not only time but also patience. I am totally lost in searching the file. Does MS excel keep backup?...
Read moreI have noticed that my 3 year old Dell laptop has a problem in power management. Either there is a problem in this laptop or this may ne common to all laptops in this series. So i am posting the issue to know more about it. Issue is this- once I put the laptop into sleep mode, I can see that laptop takes around 4-5 seconds and quickly goes to sleep. There is a LED for power which slowly glows and dims indicating laptop is sleeping. But while I try to wake up, by pressing power button, it doesn't...
Read more
